Loose drive belts
  • e30m3ochoa
    • Aug 2012
    • 136
    Loose drive belts
    Ok, so I have a 1991 318 and for some reason a While back both my alternator and water pump belts broke off. So I replaced them with new ones and tightened them to the right tension. So recently I noticed that the the tension on those same belts are loose again. I've tried tightening them but that's as far as they go. I've had the new belts for about 3 months to me it doesn't seem right that they would be loose by now. Is there anything I can replace to get rid of that problem?
    Sent from my LG-E970 using Tapatalk
    It sounds to me like you might not have used the correct belts (a bit longer than what should have been there).
    • e30m3ochoa
      • Aug 2012
      • 136
      ah I see, well that would make sense so when I bought the belts they probably gave me the wrong ones or something. the weird part is that they did hold tension but only for a few months then they just go loose.
      • TobyB
        • 5296
        A new belt usually loosens just a bit at first, as it seats to the old pulleys...
        t
