48 or 49 will work, AFAIK (going on memory, so this could be wrong....).
The 49 is the same width + height as the 48, but it's like 3 inches longer, it will fit right in the E30 trunk mount battery tray, they've even made a hold down hole for it to fit. Might be a bit heavier, but you should be able to get a group 49 for the same price as a 48, and it will have 100-200 more CCA's and probably last longer.
Bret.
EDIT: the numbers given above are correct, but it seems that some mfg's are using different numbering and the 48 is also called a 91, the 49 is also called a 93. SOOOOOOOO, get a 48/91 or 49/93. :)
