My tach and obc(now euro clock) do not work. I replaced the si batteries because the service lights would stay on and it took care of that problem. Bad si board? Is this a ground issue? Where would I check? It's just annoying not having the tach working...
Dead tach :(
Originally posted by aintnothang View PostMy tach and obc(now euro clock) do not work. I replaced the si batteries because the service lights would stay on and it took care of that problem. Bad si board? Is this a ground issue? Where would I check? It's just annoying not having the tach working...Looking for a 3.46 or lower LSD. Lets make a deal.
LSx e36TI coming soon
Originally posted by s0urceMan, she'd be so easy to rape
check the connection of the plug to the cluster. Make sure it is snug. once together. see if it comes on..give the top of the dash a good few whacks to see if it kicks in. Since you changed the batteries and as mentioned the board isn't compromised then your connection might be loose.sigpic
Check this.
Also replace fuse 10, 12, and 21.Owner - Bavarian Restoration
BMW and European Electronics Repair and Restoration
www.BavRest.com
My Feedback Thread
Our Facebook!
Follow our Instagram!
