Thinking about an M42 track car, questions!!
  • JM35
    • May 2014
    • 42
    Hey guys,
    New member here with just a couple questions about the M42. So I'm looking to pick up a track car, and I found a pretty sweet 1991 318is with a few mods here and there. One big issue is that it has some rod knock, and the bearings need to be replaced. I understand parts wise this is fairly cheap but it is a pretty heavy DIY from what I understand. Does anyone have any links to a great rod bearing replacement DIY? Pretty handy with cars, just usually need a DIY to help kick start it, especially when I'm only used to working on N54 engines. The owner says its only about a 2 hour DIY and that its pretty simple on the 318is, but it seems a little more complicated.
    Also the car has 270k miles on the chassis, and just under 200k on the engine. I wouldnt really expect it to last much much longer than that but then again M42's arent my cup of tea.
    Here is some details of whats been done on the car and what needs to be fixed:
    �New Radiator & thermostat
     �All new front timing case gaskets (top & bottom)
     �New timing chain tensioner (new style m44)
     �New valve cover gasket
     �NGK spark plugs
     �New O2 sensor
     �New transmission fluid
     �New intake boot
     �New intake manifold gasket
     �New throttle cable
     �All new oil pan gaskets (upper & lower)
     �New fuse box cover
     �New fuel pump (in box) & pump relay
     �New Bosch Idle Air Control Valve
    Upgrades:
     �M-Tech Rear Spoiler
     �Limited Slip Differential from 87 325is
     �Ebach Lowering Springs
     Tokico Blue Struts
     �E30 M3 Front & Rear Swaybars
     �Supersprint Magnum Exhaust (headers back)
     �Custom Intake
     �New BMW emblems (front & rear)
     �Alpine Speakers all around
    Cons:
     �Engine has a rod knock (set of OEM bearings is $35)
     �Driver seat is a little torn due to previous owner
     �Dash is cracked (common in e30, it's a 1991)
     �Odometer doesn't work (gear set is $65)
    Thoughts anyone? Thanks for the help!!
    E90 335i - Sport Pkg|JB4|DCI
    E60 535i - Sport Pkg|Angel Eyes|Black Grill
    07 RX8 GT - Cobb AP|Custom Tuned|ProgressTech Sway Bars|MazSport Midpipe
    BMW Parts Online
  • TobyB
    • 5297
    Front timing chain guides and idler will need to be done.
    At this point, figure on a mild- to- moderate refresh of the engine,
    if you're going to track it. As in, pistons probably,
    boring maybe, head freshen certainly.
    And lots of little hose and nut- and- bolt things.
    t
    • nrubenstein
      • 3148
      An M42 with rod knock is an M42 eager for the dumpster. Cheaper and easier to toss it.
      2002 BMW M3 Alpinweiß/Black
      1999 323i GTS2 Alpinweiß
      1995 M3 Dakargelb/Black
      - S50B32/S6S420G/3.91
      1990 325is Brilliantrot/Tan
      1989 M3 Alpinweiß/Black
      • JM35
        • May 2014
        • 42
        the owner was saying the rod bearings can be replaced from underneath the car within 2 hours on jack stands?
        Not planning on it being a track killer, it will be a couple year project that will come together over time.
        I would love to do an engine swap, just dont think im quite that technical yet.
        BMW Parts Online
        • JM35
          • May 2014
          • 42
          Here's the link to the CL post, its a very clean car, just going to need some maintenance. Any more thoughts after checking it out?
          BMW Parts Online
          • HennaE30
            • Apr 2014
            • 1965
            Not how far your willing to go, but up here in Dallas there was a really nice 90 or 91 318is for sale for $2800, had a really clean interior too
            Originally posted by flyboyx
            how about if i yank the anal beads out of your ass like i'm trying to pull start a chain saw?
            Originally posted by Northern
            beer is my new liver cleanse.
            Henna - '84 Hennarot 325e
            Lola - '89 Schwarz 325is - being saved
            Christine - '88 Schwarz 325is - Spec E30 Racecar
            '01 White F150 Lariat 4x4 Supercrew - Daily
            Dad's '05 Interlagosblau M3
