injector sizing question
  • danval
    • Mar 2013
    • 191
    Quick question. What are the main symptoms of too big injectors on an overall stock motor? Well, thats besides the black smoke.. thanks
  • Navarone
    • Jun 2014
    • 935
    Doesn't o2 sensor feedback adjust injector duration?
      • 37833
      Why not just tell us what engine and injectors you're running?
      Grover Beach, California
      BimmerHeads.com
      • DesertBMW
        • Aug 2011
        • 1038
        many bad things, too much fuel will wash the cylinders from oil lubrication and promote faster engine wear. Bigger injectors do not give more power. Injector size is matched to the air flow meter.
        • mitchlevy7
          • Aug 2011
          • 672
          running rich.....
          your injectors should match your tune.
          www.cp-e.com
          1989 Zinno 325i m52 turbo coupe
          2015 Ford Fiesta ST, Daily Driver.
          • danval
            • Mar 2013
            • 191
            Sorry I didnt give more info. Its an m20b27 I head. I dont know what injectors are they. I believe they are light grey. Im actually waiting to do a turbo setup, thats why im not to concerned with changing them, but im trying to figure some stuff out. Thanks again
            • AndrewBird
              The Mad Scientist
              • 11898
              Stock M20 injectors are grey, but i and e injectors are different. What ECU are you using?
                • 34844
                eta injectors are low impedance. if you used those with a B25 computer, it would fry the injector drivers.
