My coolant light came on the other day. No leaks, no fluid loss, no overheating, nothing to make me believe that anything is wrong with the system. Just to be sure I replaced my coolant res cap. The light is still on. I've driven the car all over the place and no coolant/overheating occurred. Hooked up the code reader, the only code that came up was : 1, DME self test. Don't really know what to do next or if I should be looking at replacing sending units. Any and all advice appreciated. Thank you for your time in advance.
At a bit of a loss with coolant light and code
Your coolant level sensor is bad, replace it and you should be good.Comment
Either that or it is gunked up with stuff. It's a float, so if something is holding it down, it will turn the light on. Or the connector came loose or there is a broken wire.Comment
I've been trying to figure out with no luck, is it possible to bypass this sensor? like with the brake pad sensor?
Sent from my iPhone using TapatalkOriginally posted by flyboyxhow about if i yank the anal beads out of your ass like i'm trying to pull start a chain saw?Originally posted by Northernbeer is my new liver cleanse.
Henna - '84 Hennarot 325e
Lola - '89 Schwarz 325is - being saved
Christine - '88 Schwarz 325is - Spec E30 Racecar
'01 White F150 Lariat 4x4 Supercrew - Daily
Dad's '05 Interlagosblau M3Comment
