clunking underneath by the shaft hump.
  • long tall eta
    • Jul 2010
    • 1536
    guys, the other day i had to mash the brakes due to an ass hole in front of me. from then on, every time i use the brakes, i have a clunking under the car by the hump on the pass side. brakes are good. the clunk only happens when i hit the brakes. levent says it is probably a broken rubber mount by the bell housing that is letting the drive train slide forward. i loaned out my jack and stands for a few days so i can't get under there. does any one have a pic of said part/mount/brace?
  • jalopi
    • 2370
    Could be a few different things, definitely inspect before you buy parts.
    Also, the only rubber bits next to the bellhousing I can think of are the control arm bushings, that wouldn't make the drivetrain slide forward though (do you still have a radiator? lol)
    • long tall eta
      • Jul 2010
      • 1536
      Also, the only rubber bits next to the bell housing I can think of are the control arm bushings, that wouldn't make the drivetrain slide forward though (do you still have a radiator? lol)
      yes, i do have a rad. lol. but i was told to look at the rad and inspect for evidence of damage. the sound is not a random one, what ever it is, it is with the revolution of either the wheels (which i doubt cause it seems to be in the middle of the car) or the drive shaft. she accelerates strong and cruises w/o any noise or vibration. only on braking does the problem occur.
      • ahlem
        • 369
        Check your motor mounts.
        • G-Man the Visionary
          • Apr 2013
          • 543
          Replace with fun, sturdy, "streetable" poly mounts.
          Link below..
          Streetable poly mounts, trans mounts are here!
          http://www.r3vlimited.com/board/show...ght=streetable
          '94 318i
          '07 335i
          '11 X5
          '89 325ic m30b35
          • AndrewBird
            The Mad Scientist
            • 11898
            Levent was probably talking about the trans mounts. They are like miniature motor mounts.
            • long tall eta
              • Jul 2010
              • 1536
              not the trans mounts, there fine. he said it's by the bell housing where the trans is connected.
              • jalopi
                • 2370
                Call me crazy, but I'm pretty sure that part number 2 in that diagram is a trans mount.
                I'm no e30 expert, so I can't speak for every model ever made, but there are no drivetrain mounts (as far as I know) between the engine mounts and the trans mount. The only bushings someone could misconstrue as drivetrain mounts/bushings and are right next to the bellhousing are the control arm bushings.
                Have a friend get in the passenger seat and take a video so we can hear the noise.
                • long tall eta
                  • Jul 2010
                  • 1536
                  my bad, that is a trans mount.
                  i'm wondering if the csb broke free? it sucks i cant get her up high enough (lent jack to friend) to pull the heat shield. only makes the noise when braking and it is definetly against the hump between the pass seat and the console.
                  • LJ851
                    • 7919
                    There is a mount that keeps the engine/trans from shifting forward but it would be difficult for it to fail. If the noise and rubbing happen at the tunnel between the seats i would look at the trans mount first.
                    Lorin
                    The M30 is God's engine.
                    • long tall eta
                      • Jul 2010
                      • 1536
                      trans mounts a only 3 years old and i was able to get under there enough to confirm that they are ok. what is the mount that you speak of?
                      • jalopi
                        • 2370
                        Do they visually look OK or did you try jacking it up a bit to see how far the engine/trans moves?
                        • LJ851
                          • 7919
                          14 is metal, 15 is rubber
                          Lorin
                          • jalopi
                            • 2370
                            What is 14/15? Some sort of vibration damper or something? Doesn't look very important
                            • pventojr
                              • Jan 2010
                              • 18
                              If you field he nock noise went tap on brake pedal it could by control arm bushing on the loli pop is broken, drive the car and tap brake pedal couple times and goin to field the tire moving back and forward
