Cleaning engine block before new HG+ thoughts on copper?
  • thatphysicsguy
    • Mar 2013
    • 843
    Hey so I'm in the middle of a HG job, and I've gotten the head off to a machine shop for resurfacing.
    The block is mostly clear save for some very thin residue. I've gotten all the big stuff off, but do I need to get every last little bit of film so the block is completely clean? or is a light going-over with a putty knife enough to get the job done?
    Also using the copper headgasket spray. Recommended? how should I go about using it?
    '91 325i
    A putty knife may not be enough. Work over the block with a scotchbrite pad. If you use the copper spray, spray it on both sides of the gasket. It isn't really needed with an OE/OEM gasket, but it won't hurt.
    • TobyB
      • 5213
      I use a razor scraper, then chemicals. Baby's- butt smooth, and clean, or it won't seal.
      I don't use sealers. I don't (usually) get leaks afterwards.
      t
      • jalopi
        • 2370
        Just note that there will be "stains" in the mating surface that you won't be able to really get out without milling the block/head.
        Free Shipping - 3M 07447 with qualifying orders of $109. Shop Scuff Pads at Summit Racing.
        best shit ever for cleaning head gasket surfaces IMO. combo with a little bit of spray 9 and elbow grease, it'll be as clean as it's gonna get this side of a machine shop
        • Dirty325ix
          • Sep 2012
          • 689
          Even if its not 100% required I like to get it as clean as possible for peace of mind..... I still think about the small spot I couldn't get completely cleaned
          • thatphysicsguy
            • Mar 2013
            • 843
            Well sweet, I already have scotchbrite laying around so I'll get to it then!
            '91 325i
            • AndrewBird
              The Mad Scientist
              • 11898
              These help as well:
              • TobyB
                • 5213
                hey, I was going to mention that a razor scraper worked pretty well... ;)
                t
                • goldenbb
                  • Jun 2013
                  • 208
                  +1 on scotchbrite but keep the vacuum running to catch all the crud.
                  '90 zinno 325iS
