Auxilary fan switch on radiator
  • jswest69
    • Mar 2014
    • 37
    Been fighting with my a/c all summer. Works fantastic if I hot-wire the compressor. Worked perfectly last summer. Anyway, just noticed that the green and black wire on the auxiliary fan switch is broken off the connector. Could this create a fault in the a/c system that would shut the compressor down? Gonna go pull a new connector later today on a scrap car and solder it in but was curious if this could be the whole damn problem.
  • vpilarrt
    • Jun 2006
    • 2096
    This happened on my 318is: The fan resistor was not making good contact with the wiring harness so the fan wouldn't come on when the AC was turned on. After a few minutes the freon got too hot and, I assume, the pressure built up until the high pressure switch in the dryer kicked on and turned the compressor off. Once I cleaned the contacts on the resistor all was good. Long story short; is your Aux fan coming on when you turn on the AC?
    • McGyver
      • 4634
      There is also a resistor in the front mounted to the aux fan that tends to go bad.
      • jswest69
        • Mar 2014
        • 37
        No, the auxiliary fan is not coming on.
        • jutilaje
          • Apr 2014
          • 11
          If it's not turning on, this is almost certainly the problem with your compressor, and you definitely shouldn't hotwire it anymore. It'll just keep building pressure till you blow whatever is the weakest component on the high pressure side. Fix your aux fan and everything else should work out.
