Stock Aux Fan for A/C
    current problem the aux fan spins super slow. do you guys know if that is normal or is my fan bad? the issue I'm having is at a stop my A/C blows warmish air and I am assuming the there isnt enough fresh air going thru the condenser. point in the right direction please. Oh and the freon is charged
    Originally posted by Rocla
    And yes, you must remove complete assembly from the car, unless you are a gynegologist
    If, by slow, you mean you can see the blades and count the revs then yes that's not good and could absolutely cause what you describe. Keep in mind that at idle the stock AC is rarely that good anyway, but the fan should spin like a fan even at low speed.
    Alice the Time Capsule
      There are also 2 speeds on that fan, (low and high) - you may want to change the resistor or check it first with volt meter
