m10 cooling fan problem need your tech knowledge here...
  • mge_1
    • Jan 2006
    • 63
    as i was driving today with my 84 318i. i heard a big thump under the hood. i found out one of the fan blade broke off and hit the inside part of the hood. it looks like my oem fan has like 6-7 blades on there. one is now missing and i noticed a little vibration now when i press the gas when i am driving it at low speeds. it kinda goes away the faster i go.
    now i guess the question is - will it mess anything up? the temp seems to stay normal. i am concern about the little vibration i am feeling. i guess its not even when its spinning anymore.
    here are the pics i took with my cell phone. hope its good enough for everyone to see.
    any feedback would be much appreciated thanks.
    Marc Enriquez
    www.revtechracing.com
  • Jand3rson
    • 37587
    Since it's missing one of the blades, the balance and the weight of it are going to be way off, and it's really not going to spin properly.
    That's probably the vibration you're getting. I would strongly reccomend replacing it, it's not hard.
    • mge_1
      • Jan 2006
      • 63
      Since it's missing one of the blades, the balance and the weight of it are going to be way off, and it's really not going to spin properly. I would reccomend replacing it.
      hmmm... ya thats what i thought. i'll call the dealership tomorrow and see if they have the whole fan. or should i just replace the one broken one.
      you think its ok to drive it for a few days or something will blow up? what do you think?
      Marc Enriquez
      • Jand3rson
        • 37587
        Replace the whole fan.
        Yes, you're ok to drive with it like it is, just get it fixed soon.
        • mge_1
          • Jan 2006
          • 63
          thanks for the confirmation buddy. i will go to the dealership tomorrow and buy the whole fan. i tried advance auto and they dont have it. thanks!
          Marc Enriquez
          • PeaveyBassist
            • Sep 2004
            • 3511
            If those are mounted on the waterpump and its been like this for a couple days, I would say you will need a water pump sometime soon.
            Will
            RIP e30 (brilliantrot '91 325i) 11/17/06 Byebye: 8/21/07
            Welcome e30 (brilliantrot '90 325is) 12/23/06
            DaveCN = Old Man
            My signature picture was taken by ME! Not by anyone else!
            If people keep quoting me in their sig, I'm going to burn this motherfucker down.
            • mge_1
              • Jan 2006
              • 63
              Will
              it just happened today. thanks for the info. but ya i'll get a new water pump too.
              Marc Enriquez
              • Jand3rson
                • 37587
                Will
                Oh yeah, good call, Will. No doubt the fucked-up rotation of the fan is taking it's toll on the pump.
                • PeaveyBassist
                  • Sep 2004
                  • 3511
                  Exactly. All that vibration on the pump could cause it to get a lot of play in it and leak/not work as well. Mostly just a preventative maitenence thing. It might not have hurt the pump at all. Who knows.
                  Will
                  DaveCN = Old Man
                  • kencopperwheat
                    King of Kegstands
                    • 14396
                    Where the F did you get that fan? Definitely not oem.
                    Originally posted by Gruelius
                    • mge_1
                      • Jan 2006
                      • 63
                      bought the car 3 months ago and thats what it had. no clue buddy.
                      Marc Enriquez
                      • AndrewBird
                        The Mad Scientist
                        • 11898
                        Looks like a really old/shitty Flex-a-lite fan that was very badly mounted to what looks like a bolt and a nut.
                        You will need a new fan clutch also with the new fan. Not positive, but I would assume they are two different part numbers. Might be a good time to switch to an electric fan.
                        Also, unless it is god-awful hot where you live right now, I would take the fan off until you get a new one. The engine should over heat unless it is really hot. Jordan ran without a fan for over a year with no problems. Just make sure you watch the temp gauge incase it does start to overheat.
                        • mge_1
                          • Jan 2006
                          • 63
                          well not too hot here in NJ right now. i normally use my 318i during night hours when i am heading to work and early morning when i am heading home. sometimes though i get some minor traffic on the way home in the morning. so you know someone ran the car without the fan?right now my main concern is the way this fan was installed. yes bolted in there with no clutch or whatever part is missing. well the bolt looks like its rusted shut in there.what i am going to do is get a replacement fan similar to this one and have a shop replace it. they should have all the proper tools to do the job i hope.
                          Marc Enriquez
