I'm suspicious that my subframe bushings and/or trailing arm bushings are worn, but I don't experience the "thumping" sound many describe, nor does the rear feel loose at all. I hear what I'd describe as a metallic "clanking" sound when going over some medium-sized and larger bumps. Doesn't seem to happen as much at highway speed unless I hit a "repaired" area of lumpy asphalt in a concrete road surface. I also hear a slight thump from the rear when I push the clutch pedal and feel a little shake....signs of a bad diff mount? I recently replaced transmission mounts and CSB, and flex disc. These aren't parts I've ever had to replace before on any car I've owned, so I'm not 100% sure of what to look for.
Diagnosing possible rear suspension issues
clanking sound over bumps - check your rear springs and rear shock mounts
thump from rear when engaging clutch - double check all the nuts/bolts on both ends of the driveshaft and the CSB bolts.
sorry, that's the best i can do. hope you get it worked out.sigpicComment
Check the bolts holding the diff to the subframe....the ones on top.
I had the same clunk with the clutch engagement, and mine was the driveshaft ujoints.2001 silver/Blk 325 cabby. SOLDOriginally posted by codyep3I hope to Christ you have looks going for you, because you sure as fuck don't have any intelligence.
2002 325xit Sil/blk. SOLD
2010 F650gs twin
2016 M235i cabby. Mineral grey/Red leatherComment
