change centering sleeve on driveshaft??
  • ptownTSI
    • Jun 2005
    • 1265
    how do you change the centering sleeve/bushing on the e30 driveshafts?
    http://www.realoem.com/bmw/showparts...22&hg=26&fg=10
    its part #1 in this picture
  • delatlanta1281
    Dart Master
    • Mar 2006
    • 10317
    There is a pressure clip.
    Yours truly,
    Rich
    you kids get off my lawn.....
    • DaN
      • 1265
      You are supposed to use a mandrel, pack the hole with grease and tap the mandrel in the hole. The hyrdaulic pressure should push it out.
      If its damaged I dont' see this method working. I had to cut the thing out.
      A slide hammer/throwout bearing puller might work too.
      When you tap the new one in, I believe it needs to protrude 4mm. And use a little grease in the hole for lubrication
      • ptownTSI
        • Jun 2005
        • 1265
        im just having the driveshaft shop take it out for me. they are also straightening the mounting flanges and changing the u-joints. local driveline shop, total cost $80. not bad.
        • turnofftheradio
          • Apr 2005
          • 448
          wow, that's a deal!
          on topic, I had a damaged one that came out fairly easy with the packed grease, the mandrel was too small since the hole was messed up. I drilled it oversize and used a larger mandrel. I ended up getting greasy on this one, but it worked.
          • ptownTSI
            • Jun 2005
            • 1265
            yep i got lucky as of yesterday he thought they were nissan u joints (hadnt taken it apart to measure exactly, just eyeballing, and were $18/piece through Dana/Spicer. the shaft had been rebuilt once before.
            • MarkH
              • Jun 2005
              • 65
              I had my driveshaft rebuilt by a local shop and he used Nissan u-joints. They use an internal clip and only require the flange be bored slightly to install them. Turned out pretty well, but he did not change the guide bushing and I now have to pull the driveshaft again to change this.
