Headunit not working after new battery installation
  • park123xyz
    • Aug 2014
    • 147
    I recently installed a new battery on my 88 iX and now the headunit does not turn on... any ideas on how to fix it?
  • ST1G
    • Oct 2012
    • 6689
    Well, personally I would start by seeing what fuse is for the head unit (if any) and make sure it's not blown. After that I pull the head unit out and see if I'm getting power to the pin on the connector. As with most electrical issues it's all about seeing how far the electricity is going.
    • Wschnitz
      • 8089
      100% sure its head unit fuse, it almost always happens, when your connecting the battery usually you accidentally touch it on and off multiple times when tightening the cable, leading to the fuse to pop to protect the HU from the surges it thinks its getting.
      willschnitz
      • AndrewBird
        The Mad Scientist
        • 11898
        Factory stereo or aftermarket?
        • park123xyz
          • Aug 2014
          • 147
          Ahh i see. Thank you!
          • park123xyz
            • Aug 2014
            • 147
            aftermarket. Hopefully its just the fuse!
            • park123xyz
              • Aug 2014
              • 147
              I checked it and it seems fine :/
              • park123xyz
                • Aug 2014
                • 147
                Its fuse 12 right?
                • itskingsteelo
                  • Jul 2013
                  • 1340
                  Happened to me when I replaced my starter too, all I did was remove and place back the fuses and bam it worked
                  Good luck
                  Originally posted by dvck
                  • jeffnhiscars
                    • Jun 2011
                    • 6010
                    There is usually a second fuse in the head unit itself.
                    Alice the Time Capsule
                    • park123xyz
                      • Aug 2014
                      • 147
                      Ahh ok thank you
