Alternator and starter problems
  • shadowbethesda
    • Apr 2011
    • 369
    I'm at a loss here. The other night I was warming up the car with the fog lights on and the headlights on. I noticed the headlights flicker as I was standing in front of the car and then the car died. I attempted to restart it and the battery was dead... Odd.
    I recharged the battery and had it tested, and it's good. I popped the battery back into the car and noticed that the starter turns over very slowly the first few seconds. After the initial slow revolutions of the starter, the starter turns over normally and starts the car. Evry time I try to start the car, the starter is behaving the exact same way.
    The other issue is that the alternator is not charging the battery.
    Could this be a grounding problem or did the starter and alternator both decide to get sick at the same time very suddenly?
    1989 325i Cabriolet Auto
    1990 325i Coupe Auto (sold)
    1987 325i Cabriolet Manual (sold)
    1989 325i Cabriolet Auto (sold)
    1991 325i Coupe Auto (sold)
    1991 325i Cabriolet Manual (sold)
    1990 325i Sedan Auto (sold)
    1984 318i Coupe Auto (sold)
  • spdracrm3
    • Sep 2009
    • 959
    voltage drop test your powers and grounds under load to find bad/loose connection or bad cable.
    does alt/charge lamp in cluster come on key on and go off engine running? what is voltage at battery and at main cable of Alt?
    Angus
    88 E30M3 X2
    89 325IX
    92 R100GS/PD
    • shadowbethesda
      • Apr 2011
      • 369
      The battery light is only on when I have the key on accessory. No light otherwise. I'm reading 13.5 volts at idle with no load. 13 v with load (high beams, fogs and rear defroster fan on).
      • shadowbethesda
        • Apr 2011
        • 369
        What range values using a multimeter should I be checking and seeing?
        • E30darkknight
          • Sep 2009
          • 422
          This sounds like a ground issue, check the main ground in the engine bay. Make sure it has no corrosion, if it does replace it even if it doesn't look bad. I replace my alternator last week, when it was just a bad ground.
          • shadowbethesda
            • Apr 2011
            • 369
            That's what I have been suspecting.
            Is there a picture or a thread of all locations of the ground cables?
            • shadowbethesda
              • Apr 2011
              • 369
              This is a video of the starter problem.
              • Gregs///M
                • Mar 2012
                • 2459
                There is only one ground in the engine bay. It runs from the oil pan to the frame rail on the drivers. Its responsible for grounding all engine electronics including the alternator and starter.
                It is imperative that this cable be in good condition and secure.
                Other non-critical grounds do exists but they are more like anti-static straps for the radio reception. One from the engine hood to the radiator support and one from the valve cover to the battery try, both braided straps.
                Owner - Bavarian Restoration
                BMW and European Electronics Repair and Restoration
                www.BavRest.com
                My Feedback Thread
                Our Facebook!
                Follow our Instagram!
                • spdracrm3
                  • Sep 2009
                  • 959
                  that sounds like a starter issue to me ,but do check voltage drop to confirm its not a cable issue ,especially ground side as mentioned
                  13.5 is normal and indicates alt is charging ,one thing to note is that sometimes when starting the idle isnt high enough to self excite the windings of alt and it wont be charging (usually alt/charge lamp is on after start ),you blip the throttle and light goes off and it starts charging . you'll see this question come up from time to time on forum (why doesnt my charge light go out sometime after starting?) . so if you let it idle a long time in that state it will eventually discharge the battery ...
                  Angus
                  88 E30M3 X2
                  89 325IX
                  92 R100GS/PD
                  • Andyp
                    • Aug 2014
                    • 31
                    I ordered this strap and it's on the way. But I was wondering how you replace it, can it be done from the top, or from beneath? Also, I think it's on the passenger side, am I correct? I'm sure it's just a couple of bolts, and cleaning the contact area before installing the new one
                    • dnguyen1963
                      • Nov 2011
                      • 2651
                      "It runs from the oil pan to the frame rail on the drivers"
                      • Dirty325ix
                        • Sep 2012
                        • 689
                        and in my experience some chemicals and a wire brush is all you need to clean it.....don't really have to get a new one(maybe I'm just cheap)
                        • shadowbethesda
                          • Apr 2011
                          • 369
                          What is a voltage drop test? What is the procedure?
                          • shadowbethesda
                            • Apr 2011
                            • 369
                            Actually I just found this:
                            Voltage Drop Testing
                            Copyright AA1Car
                            Does your engine crank slowly or not at all, but when you test the battery and starter both are fine? What about an alternator that puts out its normal charging amperage but can't keep your battery fully charged?
                            An often overlooked cause of these kinds of problems is excessive resistance in the high amperage circuit. Loose, corroded or damaged battery cables or ground straps can choke off the normal flow of current in these circuits. And if the current can't get through, the starter won't have the muscle to crank the engine and the battery won't receive the amperage it needs to maintain a full charge.
                            Nasty looking battery terminals that are blooming with corrosion obviously need cleaning. But many times corrosion forms an almost invisible [COLOR=blue !important][COLOR=blue !important]paper[/COLOR][/COLOR]-thin barrier between the battery terminals and cables. To the naked eye, the terminals and cables look fine. But high resistance in the connections is preventing the high amp current from getting through.
                            The same goes for battery cables with ends that have been beaten or pried out of shape, or have had the ends replaced. If the clamp isn't making good contact with the battery terminal all the way around as well as its own cable, the cable may have too much resistance and restrict the flow of current. The same goes for ground straps that have loose or corroded end terminals, or make poor contact with the engine or body.
                            Cranking problems can also be caused by undersized [COLOR=blue !important][COLOR=blue !important]replacement [COLOR=blue !important]battery[/COLOR][/COLOR][/COLOR] cables. A wire's ability to pass current depends on the gauge size of the wire. The fatter the wire, the more current it can safely handle. Some cheap replacement battery cables use smaller gauge wire, which may be camouflaged with thicker insulation to make it appear to be the same size as the original cable. But the cable doesn't have the capacity to handle the current.
                            It doesn't take much of an increase in resistance to cause trouble. Let's say a 120 amp alternator operates in a circuit that has a normal resistance of 0.11 ohms. If that resistance were increased to 0.17 ohms because of a bad wiring connection, the alternator's maximum output would be limited to 80 amps. In other words, an increase of only 0.06 ohms (almost nothing!) would reduce the alternator's maximum output by almost a third! Under light load, the drop in charging output might not even be noticeable. But in a high load situation, the alternator wouldn't be able to keep up.
                            CHECKING CONNECTIONS
                            If you use an ohmmeter to measure across a heavily corroded battery cable or ground strap connection, or one with only a few strands of wire that make contact with the end clamp or terminal, the connection may read good because all you're measuring is continuity -- not the ability to handle a high amp current load. The connection may pass a small current, but when a heavy load is applied there may not be enough contact to pass the extra current.
                            So how do you find these kinds of problems? You do a voltage drop test.
                            VOLTAGE DROP TEST
                            A voltage drop test is the only effective way to find excessive resistance in high amperage circuits. It's a quick and easy test that doesn't require any disassembly and will quickly show you whether or not you've got a good connection or a bad one.
                            To do a voltage drop test, you create a load in the circuit that's being tested. Then you use a digital [COLOR=blue !important][COLOR=blue !important]volt[/COLOR][/COLOR] meter (DVM) to measure the voltage drop across the live connection while it is under the load. Voltage always follows the path of least resistance, so if the circuit or connection being tested has too much resistance some of the voltage will flow through the DVM and create a voltage reading.
                            If a connection is good, you should find little or no voltage drop and see less than 0.4 volts for most connections, and ideally less than 0.1 volts. But if you find more than a few tenths of a voltage drop across a connection, it indicates excessive resistance and a need for cleaning or repair.
                            CHECKING THE STARTER CIRCUIT
                            To check the starter circuit for excessive resistance, you need to measure the voltage drop at the battery, battery [COLOR=blue !important][COLOR=blue !important]cable [COLOR=blue !important]connections[/COLOR][/COLOR][/COLOR] and starter while the engine is being cranked.
                            The first check is "available battery voltage." For the starter to crank at normal speed, the battery must be at least 75% charged (12.4 volts or higher). Low battery voltage can not only affect the starter but every other electrical system in the vehicle.
                            A. Set your DVM to the 20 volt scale, then [COLOR=blue !important][COLOR=blue !important]connect[/COLOR][/COLOR] meter positive (+) lead to battery positive (+) post (not the clamp or cable), and the meter negative (-) lead to battery negative (-) post.
                            B. Disable the engine so it will not start when it is cranked. (Ground the ignition coil wire, or disable the ignition circuit or fuel pump relay.) Limit cranking time to 15 seconds or less.
                            C. While cranking the engine, record the volt reading on the DVM. D. Next, connect your meter positive (+) lead to the battery terminal stud on the starter, and the meter negative (-) lead to the starter housing.
                            E. While cranking the engine, record the volt reading.
                            F. Compare the two voltage readings. If both are the same, there are no excessive voltage drops on the positive feed side.
                            G. If available voltage at the starter is not within one (1) volt of battery voltage, there is excessive voltage drop in the circuit.
                            The next test is for voltage drop on the positive side of the starter circuit.
                            A. Make sure the battery is fully charged.
                            B. Disable ignition.
                            C. Set DVM on 2 volt scale.
                            D. Connect meter positive (+) lead to positive (+) battery post, and the meter negative (-) lead to the battery terminal stud on the starter. While cranking the engine, record the voltage reading.
                            The maximum allowable voltage drop including the solenoid or external relay in the starter circuit should be 0.6 volts or less.
                            If you find more than a 0.6 volt drop in the starter circuit, you can isolate the bad connection by using the following voltage drop tests.
                            * Check the positive battery post and cable connection by measuring the voltage drop between the two while cranking the engine. Connect the meter positive lead to the battery post and the meter negative lead to the cable clamp. A good post/cable connection should have zero voltage drop.
                            * Check the positive battery cable by measuring the voltage drop end to end while cranking the engine. Connect the meter positive lead to the clamp on the positive battery cable, and the meter negative lead to the end of the cable at the starter. Crank the engine and note the voltage reading. A good cable should have a voltage drop of 0.2 volts or less.
                            * To check the starter solenoid or relay connections, connect the meter positive lead to positive battery terminal on the solenoid or relay, and the meter negative lead to the starter motor terminal. Crank the engine and note the reading. A good connection should have a voltage drop of 0.2 volts or less.
                            Next, you need to check the negative side of the starter circuit. To check the entire circuit, connect the meter positive lead to a clean spot on the starter motor case and the meter negative lead to the negative battery post. Crank the engine and note the reading. The voltage drop on the negative side should be 0.3 volts or less.
                            If the voltage drop is too high, set your DVM to the 2 volt scale and start checking each connection on the negative side to find the bad connection or cable. Use the DVM leads to check across each connection while cranking the engine as before.
                            Check the negative battery post/ground cable connection (should be zero voltage drop).
                            Check the negative ground cable from the battery to the engine (should be 0.2 volts or less).
                            Check between the negative battery post and starter housing (should be 0.3 volts or less).
                            Check between the engine block and starter housing (should be 0.10 volts or less).
                            CHECKING THE CHARGING CIRCUIT
                            To check the alternator connections on the positive side for excessive resistance:
                            A. Set DVM on 2 volt DC scale.
                            B. Connect the meter positive lead to the alternator output stud (B+ terminal).
                            C. Connect the meter negative lead to the positive (+) battery post.
                            D. With the engine running at 1,800 to 2,000 rpm with all lights and [COLOR=blue !important][COLOR=blue !important]accessories[/COLOR][/COLOR] on (except the rear electric defroster), check the voltage drop reading. It should be 0.5 volts or less. If higher, the connections between the alternator output stud and battery need to be cleaned. Also, look for loose connections or undersized cables.
                            To check the alternator connections on the negative side for excessive resistance:
                            B. Connect meter negative lead to alternator case.
                            C. Connect meter positive lead to battery negative (-) post.
                            D. With engine running at 1,800 to 2,000 rpm with all lights and accessories on (except rear defogger), check the voltage drop reading. On the negative side, it should be 0.2 volts or less. If excessive, the connections need cleaning or the negative cable needs to be replaced. Some alternators are mounted in rubber bushings and have a separate ground strap. If so equipped, be sure to check the voltage drop across this strap, too.
                            • shadowbethesda
                              • Apr 2011
                              • 369
                              It seems the starter is definitely finished. Ground wire replacement didn't help either. Bad luck I suppose.
