Thermostat bypass valve delete questions
  • snaponbob
    • Oct 2014
    • 34
    It seems that this is a common delete. Who can provide help on the procedure? I am most concerned with the SMALL hose coming off of the bypass valve, and it's routing. P/N is 64118391926.
  • efficient
    • Feb 2012
    • 3312
    This guide will show you how to properly bypass your throttle body heater. Parts needed spare thermostat housing spare throttle body plate 1/4-18npt bolt or plug m12x1.5 bolt m14x1.5 bolt 2 crush washers Tools needed drill press or hand drill various drill bits bench vise m12x1.5 tap m14x1.5 tap 1/4-18npt tap tap handl
    • snaponbob
      • Oct 2014
      • 34
      Whoof !!!!!!!!!
      But I was referring to THIS one.... http://www.ecstuning.com/Search/thermostat/ES177574/
      • efficient
        • Feb 2012
        • 3312
        oh that hose. i did this to a late model e30 and just bought the hose from a early model. early models didn't have a heater valve. so you keep the t hose that goes from the coolant bottle on the driver side but you take the hose off from the back of the head and you connect this hose
        http://www.bmaparts.com/item.wws?sku...E&weight=0.110
        using the hose from the early model deletes the heater valve. hope it made sense
          • 37833
          No need to customize anything to delete that bypass valve. Simply order a new thermostat housing to heater core hose and new cylinder head to heater core hose and install them. I remove that valve on every E30 I touch.
          Grover Beach, California
          BimmerHeads.com
