Question for those with the SMT-6 maf conversion
    In getting the volatge singles correct from the MAF to the ECU did you have to adjust the signal by any more then 14% at any range? I'm looking for cheaper ways to do the conversion and may of found one but it only allows 14% range of adjustment of the signals.
    85 325e 2.7 ITB'd stroker
    mine was something like adding .5 - .8 volts across the range to make it match up decently.
    Michael Spiegle
    '01 Ford Escape / Daily Driver
    '99 M3 / Track Car
    '87 325is bronzit / wtf car
    '06 Daytona Triumph 675 / Daily Rider
      cool you said the starting value at idle was 1.33 volts right? so that should be with in 14% of it. This unit is $175 but will require custom wiring and maybe a GM maf.
        What unit is that,
        Does it allow for ignition tuning, possible boost control, nox control, and other ?
        Gunni
        @ Prodrive / Aston Martin Racing
          It's made for GM LS1's and eclipse and only allows for the fuel ratio changes no timing, no boost.
          The unit is Called a MAF Translator.
            sounds kinda expensive for a $20 circuit...
            but i guess still cool if it works. Are you going to try one out?
            Michael Spiegle
            '99 M3 / Track Car
              I may try it. I'd get the SMT-6 but want just the bare basics. If I new who to make the ciruict I'd make one, the unit is almost identical to the split second kit but uses internal knobs instead of external.
