So a couple of hours ago I went and dropped my brother off at school, and then parked the car in my garage. Nothing out of the ordinary happened, but when I went to move it now, the coolant light on the check panel was on, and I had a huge puddle of coolant under my car. I looked around, and I took a couple of pictures of where I think it's coming from. What is this part, and why would I suddenly start leaking?
Coolant Leak- HELP!
i recently changed my thermostat and proceeded to lose 2 tanks of coolant before i got all the hose clamps tightened down enough to stop the leaks
so inspect all the rubber hoses and give the hose clamps a couple turns. i find a 6mm socket works much better than a screwdriver...especially for those clamps that are out of reach without a univeral joint and a long extensionJames
'88 M3
ok so i need help ordering a replacement hose... its a water that goes from the throttle housing to the valve cover... i order this part, thinking it was it:
Part Number 13-54-1-719-967-M21
"Water Hose, Throttle Housing Small Hose, 325/e/i/is/iC,iX (09/87-91)"
BMW 3-Series E30 (1983-1991) - Water Cooling System - Water Pump, Thermostat & Hoses - (Water Hoses)Water Cooling System auto parts for BMW 3-Series E30 (1983-1991): Water Hoses and other parts related to Water Pump, Thermostat & Hoses
but it's not the right hose. the hose i need has one opening that's larger than 3/4" (about .81) and the other is 1/2. is this wat i need?
Part Number 13-54-1-719-966-M101
"Water Hose, Thermostat Housing to Throttle Housing, 325/e/i/is/iC,iX (09/87-91)"
Water Cooling System auto parts for BMW 3-Series E30 (1983-1991): Thermostat Housings and Parts and other parts related to Water Pump, Thermostat & Hoses
help would be greatly appreciated.... it sucks to be stuck at home because i don't have a car that wants to run without a huge coolant leak
[/URL]
:(^SOLD^:(
Originally posted by czag13ok so i need help ordering a replacement hose... its a water that goes from the throttle housing to the valve cover... i order this part, thinking it was it:
[/URL]
You need to go to realoem.com and look at the diagram for your car. You should be able to choose the right hose from there.
