Sunroof handle loose
  • ganicuss
    • Oct 2014
    • 10
    My sunroof handle works perfectly, but when I want to put it in the the up position it won't stay, any quick fixes?
    Emergency Tree Removal AU
  • uturn
    • Dec 2010
    • 1007
    Maybe the tracks?
    • DesertBMW
      • Aug 2011
      • 1042
      these wear out all the time, you need a new one then it will stay up
      • Cosmic Serpent
        • Mar 2012
        • 154
        I glued a small but strong magnet on the base of the crank to combat the floppiness. I can post pic tomorrow if you like.
        • Delta
          • Oct 2014
          • 34
          I wrapped some electrical tape around the middle of the handle, just enough friction to keep it up and out of my way :)
          • Hooffenstein HD
            • Nov 2012
            • 1388
            I've been turning mine around and pushing it right up between the visors. Would be nice to fix it properly though.
            • raudonis
              • Jan 2013
              • 184
              Fixed 2 of these that were just flapping around, I don't use sunroof very often and it holds for me just fine.
              Remove the handle off the car using a screwdriver, put it in a in a vice and carefully apply some pressure on dull grey metal parts that are hugging the shiny handle to reduce the gap between them. Go in small steps, remove it from the vice to check if it is not too tight. Reinstall. Thats it
              There are two small rods that are pushed out by the small (but stiff!) spring you can see in the picture, they fit in round holes that are present in the grey part where the handle position is fixed. As time goes by the gap in the grey part increases and holes wear out a little - handle starts flopping around loose.
              My transaction feedback on r3vlimited :):Clickety click
              • dewme5
                • Mar 2014
                • 165
                I bought a brand new one from BAV, non-genuine BMW. Worked for 2 days. :(
                • e30 gangsta
                  • 3877
                  Place in vice. Done.
