cluster question.
  • long tall eta
    • Jul 2010
    • 1536
    cluster question.
    guys, the speedometer and the econo meter on my 87 es aren't working. every now and again they do function for a bit like when i hit a bump and she's warm.. are these soldered connections on the back of the cluster? if so, it should be an easy fix right? and if not, what else could it be?
  • reelizmpro
    • 9531
    Try reflowing the solder joints on the speedo and main pcb while you're in there.
    88 M3 - LACHSSILBER
    89 M3 - ALPINEWEISS II
    • AndrewBird
      The Mad Scientist
      • 11898
      I'd check the connector at the speed sensor on the diff. The wires get brittle and break. Without a speed signal, the economy won't work.
      • long tall eta
        • Jul 2010
        • 1536
        speed sensor at diff is ok. wires are good and connected. so if the problem is the solder in the cluster, does anyone have a pic of the connection? i have never pulled a cluster and don't wana screw this up.
        • estoguy
          • May 2013
          • 1087
          The cluster is easy to pull... there are DIYs out there. This was one of the first things I did with my car, actually. The temp gauge and SI board were FUBAR and the speedo wasn't accurate. I had two spares, and cobbled it together between the two.
          Check the SI board too, and the grounding nuts at the back, while you're at it. If you need to find spares, just remember that the cluster you pull from HAS to be the same colour - there are two: Blue back and white back.
          However, it does not matter if its VDO or MotoMeter - as long as the back is the same colour, you can swap components. Right now I have a MotoMeter Speedo in a VDO cluster, for instance.
          Estoguy
