'87 325 antenna not moving
  • nickle94
    • Nov 2014
    • 6
    So I just bought my '87 2 weeks ago, was told nothing is wrong and boy is that a lie.
    Right now I am trying to fix my antenna, it doesnt move even when I tried to pull it out.
    Any tips or threads to help me fix this problem? (Yes I am a straight noob, this is my first BMW)
  • ColonelMustard
    • Jun 2013
    • 120
    Mine is the same. I pulled back the mouse fur in the trunk to look at it and realized it wasn't even plugged in. So I plugged it in and still no movement or any change. After a few min of fiddling, I felt the antenna and it was hotter than hell. So I unplugged it and haven't cared enough to look into fixing it.
    Basically what I'm saying is check it to make sure it isn't super hot from the seized antenna and the electric motor still trying to move it. You wouldn't want to start your presumably new car on fire.
    I've seen some ppl swap in a z3 antenna if you really need the radio, and I would do some searching in the audio section. You're not to be the first to encounter this problem.
    1987 325 w/ M52b28 - Bronzit
    2007 X3 - Platinum Bronze
    • haggardfab
      • Sep 2011
      • 283
      its pretty common for them to die, your cars almost 30 years old..
      you can replace it with an aftermarket unit or find another oem working one and swap that in
      btw, its a power antenea, you cant pull it out by hand..
      IG: haggardfab
      • nickle94
        • Nov 2014
        • 6
        already tried, wouldnt budge.
        • E30NJ
          • Aug 2013
          • 921
          http://www.ebay.com/itm/BMW-E23-733i...56fd87&vxp=mtr
          • stonea
            • 2892
            I would suggest checking out the Z3 antenna swap. Its very simple and might be cheaper than getting that antenna on eBay. Also I think it looks better.
            My Garage
            Feedback
            Instagram: Stone.Hopkins
            • rcsoundn1
              • Nov 2012
              • 3361
              Thats what he is saying though, it can not be torn out by hand because of how it is made. Look into the z3 option, for most its a lot cheaper and easier to do that. GL
              • TimeMachinE30
                • Jun 2014
                • 3749
                Take it out and fiddle with it. I have a spare one which seems to be having an issue with the circuit board. The motor purrs. The power just is not making it through from the connector to the PCB and into the motor.
                It is a pretty simple gadget. I'm trying to make mine work to preserve originality.
                As stated before.... For less money than a newer motorized antenna you can get the Z3 antenna. It is a much simpler piece and should give long service. Looks nice too.
                ACS S3 Build / Dinan 5 E34
                • Das Delfin
                  • Sep 2014
                  • 2293
                  The antenna on my '87 was seized halfway up the shaft. I took the shaft out of the motor and tried extending and condensing it but it had rusted on the inside and was seized. I got pissed and threw in a classic non-retractable mast antenna from Advance auto. $12 beats a $50 craigslist used one that may only work for one season, especially when I'd just put in an ipod stereo.
