Hey guys just picked up a 318is. i had a bad resistor in the blower motor so i replaced that and my blower worked at all speeds. i also had a abs light on so i go to replace the relay and needless to say i could not find the realy. i found a relay that was a 4 prong relay just hanging under my ecu by a few wires. with a bracket on the relay. i looked above the ecu where the abs relay should be and it was not there. i figured i would mess with it later and i put everything together start the car and my tach, fuel, temp gauge dont work neither do any of my hvac controlls. when i start the car for a second the heat will blast and the tach will work then they all just die. speedo works thought. what could possibly control both the gauge cluster and hvac? head lights turn signals high beams abs lights all work. so i dont really know what to do. any help would be great as i am a noob to these cars at the moment.
Thanks
Thanks
