I have the sachs clutch kit. I am currently building a 2.7 i stroker. I would like to run a sachs sport clutch or ie clutch. Where can i find the sachs sport clutch, and can i use the same pressure plate i have now or must i upgrade?
Clutch upgrade.
Tags: None
I got my sachs sport clutch from bavauto.. I have no idea who else sells them or if you can get them cheaper. I didn't care, I just wanted to order it, no time for comparison shopping. you use it with the stock pressure plate, but you have to use the sachs sport TO bearing. -
Awesome thank you. How does it feal compared to a normal sachs clutch? Also if i decide on the Ie route do i need to get a diffrent t/o?Originally posted by nandoI got my sachs sport clutch from bavauto.. I have no idea who else sells them or if you can get them cheaper. I didn't care, I just wanted to order it, no time for comparison shopping. you use it with the stock pressure plate, but you have to use the sachs sport TO bearing.Comment
I don't know how it feels, it's not in yet :p
the IE kit might use the stock TO bearing, I don't know. The sachs sport TO bearing was just a requirement for my kit.Comment
