Sunroof issue! Help!!! Pics!!!
  • blizake500
    • May 2014
    • 424
    I have a 2003 e46 m3. I'm not getting help in the m3 forum so I thought you guys could help. Ok so I pushed the center button to make my sunroof flip up and I didn't slide back my headliner first. The sunroof made weird popping noises. The sunroof is now uneven on the passenger side rear. When sitting closed the right rear corner of the glass is sitting in a low position. The other side is fine. How do I adjust the glass where it sits even with the other side? I don't think anything broke I just want to adjust it where it goes back up to be even with the roof.
    [IMG][/IMG]
  • uturn
    • Dec 2010
    • 1008
    The drive gears at the motor are probably stripped or there's an issue with the cable. Pull the motor and you should be able to slide it back by hand.
    • blizake500
      • May 2014
      • 424
      Slide what back by hand?
