can the TDC/camshaft alignment be off?
  • ptownTSI
    • Jun 2005
    • 1265
    If it was aligned each time after going around in one direction. i did not think to check rotating it the other direction.
  • arsevader
    • May 2005
    • 1025
    That makes no sense. If it's aligned when rotating it one way it's going to be the other way.
    The reason to rotate it a couple of times is to make sure that the tensioner is doing it's job and the timing is still correct. Once you do that a couple of times you are good to go.
    • ptownTSI
      • Jun 2005
      • 1265
      shit, you know what...i cant remember if i retightened the upper tensioner bolt after loosening it to tension the belt after i put it on...might have to pull that cover off yet once more... along with the fan, hoses...blah i hate that about the e30's.
      • HST
        • Jan 2006
        • 757
        Easy fix there, electric fan mod FTW! No more fan clutch madness!!!
        Originally posted by KingB
        Scratch my back and I buy a prostitute for you, to rub your balls. HAHA now thats some funny shit.
        • ptownTSI
          • Jun 2005
          • 1265
          actually i'm pretty sure i retightened it. it says right there in the bentley 16ft lbs and i know i had my torque wrench out at the time soooo. i'm gonna run with it. it already has an electric fan on there, but it has a clutch fan tooo.
