Help need to wire up fuel gauge independently
  • GT BMW E30
    • Nov 2008
    • 2491
    I want to wire up a bmw e30 fuel tank gauge to a bmw e30 fuel sender independently from the dash location. I want to run power, ground and whatever else needed so it reads the amount of gas in the tank.
  • Gregs///M
    • Mar 2012
    • 2459
    Read the schematic in the ETM manual and that will be all you need. Power, ground, and control voltage from tank floats.
    Owner - Bavarian Restoration
    BMW and European Electronics Repair and Restoration
    www.BavRest.com
    My Feedback Thread
    Our Facebook!
    Follow our Instagram!
    • GT BMW E30
      • Nov 2008
      • 2491
      I will google one.
      • GT BMW E30
        • Nov 2008
        • 2491
        So I figured out positive and negative side of gauge. I have a few questions.
        Does the gauge run on 12 volts?
        Looking at the pictures below how should I run power to it?
        Do you think I can run ground to tank and run power off remote wire connection on amp?
        BMW Fuel Level Sensor
        This connection has 2 brown/green wires running of it. I think it was spliced into the fuel sender on the main tank. I do not what to slice into any of those wires. Rather run it independent.
