HVAC fan is blowing fuses - need advice
  • clydesdale
    • 631
    The fan had been making some intermittent squeeling on speed 1 and 2. That has been going on a while. I then let the car sit for a few days over Christmas and then today the fan was not working at all. I noticed that the 30 amp fuse was fried. I swapped in a different fuse and the fan immediately worked on all 4 speeds. But, it sounded strained and on setting four it did not maintain the proper fan speed and would slow and then speed back up. It ran for about 15 seconds and then popped the fuse again.
    So, what is the deal? Do I need to replace the fan? Just bearings? Do they come as complete units? Do I buy one on ebay? I think a new one is north of $300, correct?
    Please advise. This is a daily driver in NY and I NEED a defroster for the windshield, so this needs to be taken care of. Thanks.
  • rcsoundn1
    • Nov 2012
    • 3361
    I'd say buy a well know used unit to get you through. That way you can disc yours and see if it is repairable.
    • uturn
      • Dec 2010
      • 1005
      Just buy a new fan and be done with it. The bearings are bad and you can't pull the plastic fan blade to replace them without breaking it and throwing it off balance.
      • clydesdale
        • 631
        Do I need to buy genuine BMW? As I recall, these things are VERY pricey.
        • cabriodster87
          • Jan 2011
          • 1042
          I got a nice one from my local pick-n-pull, cheap!
          Reich und Roll!
          • clydesdale
            • 631
            That is what I am hoping for. If not, it looks like I will go with a Behr one for $167 on rockauto.com. Any other suggestions?
            • DaveSmed
              • Apr 2007
              • 1407
              Side note: tempting as it may be, do not keep chucking fuses at it until you get it swapped out. Motor loads are kind of strange, and they can do a lot of damage despite the fuse. Swapping fuseboxes is not fun.
              -Dave
              2003 Lincoln Towncar | 1992 BMW 325iC | 1968 Cadillac Deville
              Need some help figuring out the ETM?
