New Late Model Heater Valve Part is Different Than Old Late Model Heater Valve?
  • Cloudbase
    • 1795
    Sooooooo.
    I took the liberty of preventively replacing my heater core and heater valve on my 1989 325is. At 250K miles, I figured it would be a good thing to do when I drained the cooling system to replace a blown head gasket.
    I sourced a BMW branded heater valve from a dealer in IL. I needed it quick and they could get it to me in 24 hours.
    To be clear, I am talking about a late model, air-conditioned car heater valve that looks like #16 in this diagram:
    Which is what this part looks like real life (although I don't believe the one in the image I found is BMW OEM, I think it's brand called Original Equipment Supplier)
    But the part I got looks like this. It has a little plastic thing on the front and brass nut on the top. It's a BMW part that came in a BMW box.
    I remember there being a heater valve recall at some point for the E30, but I can't find anything in my searching that makes sense of the different parts.
    The problem is there is a solenoid above the heater valve that the brass nut conflicts with. Not a big deal, I relocated it. Then once I got my car running my NEW OEM heater valve was leaking at the seam where the valve is. I gently tightened the 4 allen screws, but it didn't stop. So now, I'm thinking about ordering the O.E.S. one that is exactly like the old one from ECS Tuning.
    Does anyone know the difference between the original and re-designed heater valves? Jim Levie?
    JOY IS AN E30...
  • uturn
    • Dec 2010
    • 1005
    That's the new valve, apparently the same person that assembled my valve did yours. Somehow it slipped by QC. Take it apart and properly install the o-ring.
    • Cloudbase
      • 1795
      Take it apart at the allen screws. Where is the O ring? Around the seam? How was it improperly installed?
      JOY IS AN E30...
      • uturn
        • Dec 2010
        • 1005
        Yes, take it apart at the Allen screws. It'll be clear once you break it down. The o-ring was half on in its groove. I was lucky it wasn't cut. Silicone based lube and finesse got it back together. Or just send it back for warranty replacement?
        • Cloudbase
          • 1795
          Cool. Thanks...
          JOY IS AN E30...
