Voltage Regulator - removal process and reinstall- easy?
  • clydesdale
    • 631
    This is on a bosch alt. Do I just remove the airbox and then remove the two screws holding the VR in place, remove and push the new one in place and then reinstall the 2 retaining screws?
    Is there anything that needs to be lined up or just align the screws and I'm done? Thanks.
  • reelizmpro
    • 9558
    Yes, very easy. Make sure the brushes are lined up right and disconnect the battery.
    88 M3 - LACHSSILBER
    89 M3 - ALPINEWEISS II
    • clydesdale
      • 631
      Thanks for the reply. What do you mean by aligning the brushes? I see the two nubs that stick out of the voltage regulator. These are the ones that often get worn. I believe those are brushes, correct. They seem to wiggle a little back and forth. What do you do to align them?
      • ST1G
        • Oct 2012
        • 6690
        Those are the brushes.
        • reelizmpro
          • 9558
          Perhaps align wasn't the right word, more like compress the brushes. It will become apparent once you go install a new regulator.
          88 M3 - LACHSSILBER
          • clydesdale
            • 631
            ok, thanks guys.
            • clydesdale
              • 631
              There must be something to "align" the brushes. I put the new regulator in and the voltage was only 11.5. I removed it and put the old one back in and got 16.2v. I then removed the old and put the new one back in and got 14.1v. So, something was not happy when I first installed it. But, all seems good now. What the heck do you have to align. I just pushed it into place and lined up the screw holes.
              • reelizmpro
                • 9558
                You install it at an angle first so the brushes clear then they compress once fully seated.
                88 M3 - LACHSSILBER
                • Prost
                  • Nov 2012
                  • 193
                  Kind of off topic, how do you know what brand is the alternator beside taking it off?
                  92 Alpine White 325iC M-Tech II Appearance Package
                  • ST1G
                    • Oct 2012
                    • 6690
                    look for sticker or stamp?
                    • Prost
                      • Nov 2012
                      • 193
                      Are those visible from the top?
                      • estoguy
                        • May 2013
                        • 1087
                        I think mine is Bosch. It's the factory original - I did replace my regulator last spring. Still running strong after 29 years.
                        I have a new BMW reman unit I got for $100, and it only has a BMW "Remanufactured" sticker on it.
                        Estoguy
                        • Prost
                          • Nov 2012
                          • 193
                          Just took out the airbox this morning to access the alternator, it's not a bosch since there is no easily change voltage regulator visible at the back of the alternator...I guess mine cannot be a simple change...
                          • reelizmpro
                            • 9558
                            Valeo perhaps?
                            88 M3 - LACHSSILBER
                            • Prost
                              • Nov 2012
                              • 193
                              Valeo perhaps?
                              I think so, but the process is not as simple as the Bosch...
