1991 E30 Cab - In Line Heater T-stat
  • mikerob97
    • Jul 2010
    • 140
    I recently picked up a late model E30 Cab and am now going through the engine compartment replacing hoses and fixing little problems.
    I notice this car runs an in line thermostat/bypass in front of the heater core - my earlier E30 did not have such an item. Is there a tremendous benefit to having this - or is it something that can be removed on the later models?
    Thanks in advance for any replies.
    Mike
    Cary, NC
    Current Rides
    1991 325iC - For Sale
    2006 M3 Cabriolet
    Past Rides
    2000 323i Touring - Daily Driver
    1994 325is (S50) - Fast Car
    1998 Z3 - Fun Car
    1986 325e (i engine conversion)
    1969 Mustang Mach 1
  • uturn
    • Dec 2010
    • 1004
    It was installed as a safety recall, something about hot coolant burning people's feet when the heater core fails. I got rid of mine.
    • mikerob97
      • Jul 2010
      • 140
      Thanks for confirming this - it does sort of look like it was hacked in there. I will plan to remove as I replace the heater hoses.
      Mike
      Cary, NC
      Current Rides
      2006 M3 Cabriolet
      Past Rides
      1998 Z3 - Fun Car
      1969 Mustang Mach 1
      • Dirty325ix
        • Sep 2012
        • 689
        So even with the temp set on cold water still flows through the heater core?
        Or does it bypas the core through that small ass hose
        • spdracrm3
          • Sep 2009
          • 959
          with the temp dial set to the lower 20% of cold side the water shutoff valve operates and shuts off flow to core (this is for improved AC performance)
          the TSB thermostat bypasses some of the flow during overheat conditions thereby reducing chance of heater core failure due to overheated coolant
          Angus
          88 E30M3 X2
          89 325IX
          92 R100GS/PD
