1991 325iC - Heater Core Question
  • mikerob97
    • Jul 2010
    • 140
    I should have take some pictures before I took this apart, but I didn't. I am replacing the cooling hoses on my car, including the hoses to and from the heater core.
    Question: Does the short hose from the back of the cylinder head connect to the upper or lower heater core pipe?
    Thanks in advance for your rapid reply..:)
    Mike
    Cary, NC
    Current Rides
    1991 325iC - For Sale
    2006 M3 Cabriolet
    Past Rides
    2000 323i Touring - Daily Driver
    1994 325is (S50) - Fast Car
    1998 Z3 - Fun Car
    1986 325e (i engine conversion)
    1969 Mustang Mach 1
  • mikerob97
    • Jul 2010
    • 140
    no one knows the answer?
    Mike
    Cary, NC
    Current Rides
    2006 M3 Cabriolet
    Past Rides
    1998 Z3 - Fun Car
    1969 Mustang Mach 1
    • spdracrm3
      • Sep 2009
      • 959
      been awhile since i messed with these hoses , but the hot water comes out the hose on the rear of cyl head and should go to the pipe with the shut-off (electronic)valve on it . trace and attach accordingly
      Angus
      88 E30M3 X2
      89 325IX
      92 R100GS/PD
      • Das Delfin
        • Sep 2014
        • 2293
        That electronic valve was a recall part so your car may or may not have it. But if it does there should be an arrow somewhere on it indicating coolant flow
        • efficient
          • Feb 2012
          • 3312
          The hose from the back of the head connects to the bottom pipe. I would fill the heater core with coolant before putting the hoses on. It Makes it easier to bleed the coolant system.
          • reelizmpro
            • 9518
            ^agreed.
            88 M3 - LACHSSILBER/SCHWARZE
            • spdracrm3
              • Sep 2009
              • 959
              recall safety valve was a mechanical thermostatic valve (no electronics at all) and is outside the cabin in eng bay(if recall was done) , electronic valve i was referring to is the water shut-off valve that is inside the cabin and mounted on the core inlet pipe (just dont remember if its upper or lower as it goes thru firewall) but i see its been answered ....
              Angus
              88 E30M3 X2
              89 325IX
              92 R100GS/PD
              • mikerob97
                • Jul 2010
                • 140
                Thanks!
                Note that the electronic heater control valve is connected to the top pipe on my car.
                Regarding the mechanical thermostat that was "hacked" in as part of the recall - I ditched that in favor of a new, unmolested inlet hose from BMW. I recall my first E30 from 1986 did not have such nonsense, and the car developed toasty warm air on winter mornings. This Cabriolet that I recently acquired in January did not produce much heat at all - and upon further investigation, see that the Tstat was frozen shut. So it is gone, along with the plastic "T" that was "hacked" into the return hose.
                Thanks for everyone's replies - back to working on the car. I want it ready for Spring - and in NC, it is just around the corner...:)
                Mike
                Cary, NC
                Current Rides
                2006 M3 Cabriolet
                Past Rides
                1998 Z3 - Fun Car
                1969 Mustang Mach 1
