My car's had this problem ever since i learned how to drive it faster. I am pretty sure it's some sort of fuel starve problem. If I have below a half tank my car loses power mid to exit of the turn. if anyone has a fix for this i would be apreciative. i have changed the filter.
Car loses power mid turn.
what's your setup? if you're talking r-compounds on a race track at speed, then it might be fuel starvation. if you're talking fast on street tires, i dunno, shouldn't happen until your tank is running real low. check for loose vacuum hoses or something.BEERTECH
Hi there, if your car is equipped with a pre-pump in the tank and a separate main fuel pump, chances are the prepump is not working. it will suck air from the tank when the car is in the corners. I may be wrong, and this may apply for e30's from 86 and earlier or maybe 87's and earlier.Originally posted by var1anti have been keeping it at half tank or higher but it bugs me that i can't run the car below half tank.
but if the car has a prepump its a very good chance that its pooched. i use the vw intank prepump (way cheaper, and you can buy it separatly) and it solved all the fuel starvation issues at the track.
i hope this helps
daveComment
I thought i had the same problem, but it turned out the screen/filter on the bottom of the pump fell off. IF this happens, the pump is allowed to swing freely inside the tank [still mounted in the same spot, just imagine a swing set]
Check that first! If not, i have one of those resivors thats supposed to solve the issue. make offer
Originally posted by vladDo you know anybody else who built that many bad ass E30s?Comment
how do i fix the whole missing screen thingOriginally posted by Joe318isI thought i had the same problem, but it turned out the screen/filter on the bottom of the pump fell off. IF this happens, the pump is allowed to swing freely inside the tank [still mounted in the same spot, just imagine a swing set]
'87 alpine white 325isComment
