Rear knocking when when shifting?
  • bluevanilla
    • Nov 2014
    • 16
    Hi guy,
    I hear a loud knocking noise when I am shifting on 1st and 2nd. Specifically, when I step on clutch or step off the gas quickly. It won't happen on higher gear or faster speed. So it's like when I get off gas quickly or step on clutch quickly, i can hear a loud knocking noise from rear. Do you guys have any idea what can cause this?
    P.S. I have a 91 318i with 3.73 LSD.
  • efficient
    • Feb 2012
    • 3312
    I have this issue but I have condor solid bushings.
    • hooken m
      • 1537
      hows the bushing in the rear?
      Originally posted by evandael
      a car is a car. call it a dildo, i'd still drive the hell out of it.
      • 15Michaeljoseph
        • Aug 2013
        • 1693
        you got anything loose in your trunk?
        --Mike
        (OO=[][]=OO) For Life
        • bluevanilla
          • Nov 2014
          • 16
          Thanks guys. I will check and see if it is caused by the bushing.
          • rturbo 930
            • Dec 2005
            • 2629
            What kind of knocking exactly? Ie, if you let off the gas, does it knock just once? I have a rear end knock when I get on or let off the gas, and it basically sounds like there's slack in the driveline somewhere. I have a hunch it might be my driveshaft.
            • efficient
              • Feb 2012
              • 3312
              This is what mine sounds like aswell. Also when I come to stop with the clutch engaged I can hear the something moving back and forth. Shifting from 1st to 2nd gear will make my knock aswell.
              • ST1G
                • Oct 2012
                • 6689
                Check to make sure the drive shaft centre bearing is still bolted to the car.
                • bluevanilla
                  • Nov 2014
                  • 16
                  Thanks guys. It's such a great community here. Eventually, it was those nuts mounted the diff got loosen. Tighten those nuts, problem is gone :) in my case.
                  • rturbo 930
                    • Dec 2005
                    • 2629
                    Sounds like mine. If I can get the car to start bucking, it'll do it every time. I have a strong suspicion it's my DS U-joints, and failing that, my subframe bushings. I already did them, but they didn't seat right. Been meaning to fix that.
                    • mabeer
                      • Mar 2012
                      • 43
                      Incorrect diff backlash maybe?
                      Sent from my XT1080 using Tapatalk
                      • QUKBMER
                        • 8178
                        Diff mount or Subframe busings or Shock mounts or maybe it's the fact that you didn't keep your hookers in the trunk strapped down tight enough?
