Power windows change over?
    When did they change the design of the power windows? I know the later ones are smoother. I have an 88 thats rough and I dont know if I should just replace them or see about upgrading them if I have the early style. Anyone know when they updated? If mine are early style, how do I convert to the newer style?
    89 was the update.
    The old style ones last longer. Don't try to convert.
    Adam Fogg- '88 M3
    Common sense- It's the new 'gifted'
      They might last longer but they arent smooth at all. It almost drops like the last inch, and its loose.
        I updated to the newer style, they are definately consistant. Required some drilling and matching up of holes and gaskets - but worked great. If you did this, you'll need the window rails from inside the door too.
        - Sean Hayes
          Something is wrong with your early windows if they aren't smooth. I have them in my 1984 and they still work perfectly.
          Originally posted by Gruelius
            If it's that loose and screwed up then something else is wrong. Open up the door and take a look around.
            Adam Fogg- '88 M3
              What I don't understand is how the earlier method is a better design? It's a huge ass ball bearing - there are shit loads of moving parts.
              The later style has very little moving pieces, less work that the motor has to do and just plain makes more sense.
              - Sean Hayes
                Ball bearings? What are you talking about? It's a cable. One moving part.
                The later style has multiple arms that move around with those stupid plastic rollers that will break off and jam the whole mechanism. If you hit the swtich with a broken roller it'll bend the entire regulator out of shape and occasionally take the door with it.
                Adam Fogg- '88 M3
