Squealing like a mother
  • jplettuce
    • Oct 2014
    • 47
    My e30 is making this terrible squealing sound when ever the temperature drops below 50 degrees. When it is a warm day it does not make any sounds but i do hear a rattling sound when the engine is running towards the front. I think it is the belts but i just replaced all of them. I may need tensioners that arent stripped. Does anyone have a solution? preferably cheap as i am broke but i hate the squealing and i cant take it anymore. This happened before and i pushed it the point of a belt snapping. i changed the belts and suddenly its back??????
    EURO URO UR BROKE
  • AndrewBird
    The Mad Scientist
    • 11898
    Your belts likely aren't tight enough. Rule of thumb is you should only be able to turn the belt 90º along it's longest stretch and no more. See here:
    If you have any oil leaks, oil on the belt will make it slip and squeal as well.
    • jplettuce
      • Oct 2014
      • 47
      Thanks man will go to my local e30 shop lol and get some non stripped tensioners to hold the belt better
      EURO URO UR BROKE
      • george graves
        • 19993
        Nice rule of thumb. I like that. Good solid tip right there.
        Originally posted by Matt-B
