Heat shielding?
  • brainfood
    • Jun 2013
    • 129
    Heat shielding?
    Hey der guiz,
    So I'm in the middle of doing a partially shaved bay, repainting, slimming and re-wrapping the harness, and some other stuff (not tucking though, I change things too frequently to mess with that), and while I'm stripping out the engine bay, all my shield/sound deadening stuff from the firewall down into the trans tunnel pretty much just crumbled away to nothing. So essentially, I'm looking for good options to replace it. Bay is Hennarot, and I want it to look pretty good if possible, but it's not the end of the world if it doesn't.
    What are my options?
    WNY e30 Group on FB, feel free to join if you're from the area!
    @mriterphoto on instagram
    "Being airborne in an e30 is one of the worst ideas that I've done more than a couple dozen times"
    me-"I've got one of those rare 7cyl low-comp S62's"
    MattAvino- "Those aren't rare"
  • Cabriolet
    • 9620
    you can either buy it new, it is really cheap. or you can do without it if you want a nicer look. you can see it new, here in my car. it was like $100 from ecstuning.
    http://www.ecstuning.com/ES125554/
    http://www.ecstuning.com/ES125555/
    http://www.ecstuning.com/ES125487/
    you can run without it or get gold plate shielding done up to make the bay look better.
    Much wow
    I hate 4 doors
    • ThatOneEuroE30
      • Dec 2013
      • 8626
      I'd run with out it if your cleaning you bay up cause it's just gonna make it look messy
      1991 318i 4dr slick top
      Mtech 2 turbo restoration
      • AndrewBird
        The Mad Scientist
        • 11898
        You could run without it and then use something under the carpet on the inside if you are worried about heat.
