Recharge A/C?
  • rwh11385
    lance_entities
    • 18403
    Recharge A/C?
    where? how much?
    A/C stopped blowing its nice cold air.
  • Skafrog
    • 1732
    Freeze 12. Get some gauges.
    NASA MidSouth TT Director / GTS2 #018
    Mods: Coastal PS Fluid, 10w40 Oil
    Future Mods: Bosch Micro-Edge Wiper Blades, Painter's Tape, Spark Plugs, Freezer for Nutty Buddys, Adam Nitti CD's
    • trashcop 80s 80s
      • Jun 2004
      • 1130
      I got my system vacuumed out and installed a 134a conversion kit. I've been using it for 2 years now and it is still blowing cold. I have heard that it will eventually fail, but the kit I bought had a universal oil that is suppose to be good for any type of compressor. Don't know but it is still cold as shit after two years.
      • Spaz
        Crazy Canuck
        • 2276
        if its gone, theres a leak, get nitrogen fill it listen for leak, replace faulty part, then fill er up, just make sure there is no propane in the rechagre refridgerant.
        or
        replace the faulty part, put 2 converison fittings on to make it r134a, have a shop recharge it and when they do they can extract the old oil and put in compatable stuff.
        Cam .W '91 325is
        Spaz's 1991 Alpine White???? S52 Build Thread...
        • AdironRider
          • Dec 2004
          • 3491
          All e30s came with r12 correct? Mine only blows cool now and I have a 91 318is. Not sure when they made the switch from r12.
          Back to my roots
          • rs4pro3
            • 5808
            I believe it was in the early 90's my mom's 95 740i came with R134a from the factory.
            85 325e 2.7 ITB'd stroker
            • PeaveyBassist
              • Sep 2004
              • 3511
              They switched to r134a in either 1992 or 1993.
              Will
              RIP e30 (brilliantrot '91 325i) 11/17/06 Byebye: 8/21/07
              Welcome e30 (brilliantrot '90 325is) 12/23/06
              DaveCN = Old Man
              My signature picture was taken by ME! Not by anyone else!
              If people keep quoting me in their sig, I'm going to burn this motherfucker down.
              • Eric Giles
                • 1068
                Will
                It was in '93.
                Regarding the Freeze 12 stuff-I have been doing research on this topic all day because the R12 in my '88 M3 decided to take a leave of absence. The two places in my town that do a/c work are going to run dye thru the system to check for leaks and then charge with the Freeze 12. After all of my research, I am just not sure. I mean, it WILL work and is meant as a direct replacement for R12-but it still isn't the real deal.
                If you do put in the Freeze 12, and then go to an a/c shop later because of more troubles, they will usually not touch the system because evacuating the Freeze 12 will contaminate their R12 tank. General consensus by the a/c pros is that if you had a functioning R12 system that might just need a recharge with some new o-rings or a hose, then stick with R12. There is nothing out there that is truly compatible with it.
                In my case, on Monday morning I make the hour long trip to the BMW dealer and pay up for the real deal-as much as I don't want to...
                Eric Giles
                '20 M2 CS
                '04 M3
                '11 X5 35D
                '87 325is
                '91 325i Sport
                There are few things more expensive than a cheap BMW...
