Temp gauge washer, where does it go? Inside cluster or outside cluster touching nut?
  • IS300E30
    • Apr 2009
    • 406
    Does the washers that are for the gas gauge and temp gauge, go inside the cluster, touching the actual temp or gas gauge or does it go outside of the cluster touching the nut or does it not matter either way?
  • DRTSRFR
    • May 2008
    • 1836
    It goes on the outside, under the nut...
    Suspension tips here...
    http://www.r3vlimited.com/board/album.php?albumid=757
    • Gregs///M
      • Mar 2012
      • 2459
      The inside should have a spring washer, the outside should have a flat washer. Two washers per gauge. With the spring washer missing, you will most likely have inaccurate gauges, erroring on the high side.
      Owner - Bavarian Restoration
      BMW and European Electronics Repair and Restoration
      www.BavRest.com
      My Feedback Thread
      Our Facebook!
      Follow our Instagram!
