1991 Cabrio - Instrument Cluster Illumination
    All of the dash lights work The instrument cluster gauges work. I tested the individual bulbs, and they test good. However the when I install the cluster back in the dash, the dash illumination does not work. Does this sound like a problem anyone else has experienced?
    Mike
    Cary, NC
    Current Rides
    1991 325iC - For Sale
    2006 M3 Cabriolet
    Past Rides
    2000 323i Touring - Daily Driver
    1994 325is (S50) - Fast Car
    1998 Z3 - Fun Car
    1986 325e (i engine conversion)
    1969 Mustang Mach 1
    Try changing fuse 23 with new.
    Owner - Bavarian Restoration
    BMW and European Electronics Repair and Restoration
    www.BavRest.com
    My Feedback Thread
    Our Facebook!
    Follow our Instagram!
      Hey Gregs - yes I checked the fuses, all good. Removed the instrument cluster and tested the bulbs, again. Tested good. Sprayed a little contact cleaner on the socket and the mounting clips, seems to work now. I am guessing (hoping) it was just a poor contact and not the early stages of an intermittent failure...
      By the way - the starter and grounding wires work perfectly. See one of my other posts about a hot starter and ground wire...you will get a kick out of it...
      Mike
      Cary, NC
      Current Rides
      2006 M3 Cabriolet
      Past Rides
      1998 Z3 - Fun Car
      1969 Mustang Mach 1
