Engine cuts out in wide turns
  • CW325
    • Jul 2011
    • 1434
    Hey guys, I've been recently having a problem where my car will lose all throttle response only while taking exit/entrance ramps on the parkway. I'll hit the gas and nothing will happen but randomly it will start working again. I noticed my speedometer has been working on and off too and was wondering if this could be related? Anyone ever experience something similar? Motor is stock 325e m20b27
    Thank you
  • DER E30
    • Sep 2013
    • 2343
    Does it do it right after you get gas? Is it worse when the tank is nearly empty?
    -Christian
    • CW325
      • Jul 2011
      • 1434
      Seems to happens randomly, no relation to a full tank or not. Did some more research, thinking maybe main relay?
      • ak-
        • 12422
        Oil pan ground if your cluster has issues at the same time - something to check!
        1991 325iS turbo
        • CW325
          • Jul 2011
          • 1434
          Where on the oil pan is there supposed to be a ground? I don't remember seeing one so that could be part of the problem.
          • ak-
            • 12422
            On passenger side of the car looking down in the engine bay you should be able to see it connected from your pan to the chassis.
            Your car won't start or run right without it.
            1991 325iS turbo
            • CW325
              • Jul 2011
              • 1434
              Just took a look and didn't see any grounds coming from the pan maybe not all cars have one?
              • jayuuey
                • 414
                i had a similar issue and after replacing my fuel pumps, it was resolved. Its likely the low pressure in tank pump might be dead or weak. id start there first.
