Cruise control won't turn off
  • Daeldalus
    • Nov 2012
    • 304
    My cruise control just started to stay on whenever I hit the brakes.
    works fine with the clutch though.
    New stoplight switch that is confirmed working and is adjusted correctly.
    Connection cleaned for that and the brake light control module in the trunk.
    Other than not turning off when brakes applied everything works fine.
    Any suggestions? What else to check? Loose wire?
    I am stumped at this point.
  • long tall eta
    • Jul 2010
    • 1536
    is your new switch designed for cars with cruise?
    • Gregs///M
      • Mar 2012
      • 2459
      CC uses stoplight switch to inhibit CC. The wire going to the CC is probably not connected. Since that is your most recent change, I would suspect that. You might need to test the voltage logic and compare with ETM.
      Owner - Bavarian Restoration
      BMW and European Electronics Repair and Restoration
      www.BavRest.com
      My Feedback Thread
      Our Facebook!
      Follow our Instagram!
      • Daeldalus
        • Nov 2012
        • 304
        The stoplight switch was replaced as a first try to fix this problem.
        So it started before I replaced it. Also it doesn't do it all the time.
        just most of the time.
        • vpilarrt
          • Jun 2006
          • 2096
          CC is disabled by the brake switch (and clutch switch) removing the ground on the green/red wire when the pedal is pushed in. Make sure that wire is not intermittently shorted to ground somewhere. This would keep it from disengaging.
          • Daeldalus
            • Nov 2012
            • 304
            But the brake lights work perfectly. Would a short to ground not also affect that? Or is there a separate ground that is only around the CC unit?
            • Daeldalus
              • Nov 2012
              • 304
              UPDATE. my brake lights do not work perfectly.
              driving home tonight was the first time at night
              and i could see that my brake lights only worked
              some of the time and the CC worked perfectly
              when the lights were working but not when they
              were not working.
              sounds to me that i have a grounding problem
              like vpilarrt suggested earlier.
              so the question becomes, what and where
              are the most likely culprits for this?
              i can do without CC for awhile but not without
              brake lights.
              can i tap one side of the stoplight switch
              into a reliable source of power so that i
              can be sure that that power source is
              interrupting ground at the CC unit and also
              running my brake lights at the same time?
              • Daeldalus
                • Nov 2012
                • 304
                I think i have it fixed now.
                the connector on the back of the stop light switch was
                loose. when i jiggled the connector when the brakes were
                applied the green/red wire would go back to ground and
                the lights would go off.
                I tightened the connector lugs and used some dielectric
                grease in there and so far no problems. i will update again
                after a good long drive tonight
