Diretional stalk wiring harness
  • JIM1inWisconsin
    • Dec 2014
    • 116
    I was attempting to replace my directional stalk and got to the point of pulling apart the wiring harness but it is in a position that I can't get sufficient grip on it. Stupid question: do I pull on the wires and risk a greater problem or is there a more civil way of going about this?
  • jeffnhiscars
    • Jun 2011
    • 6011
    There are pinch clips on the white plastic connector although it still takes a fair bit of effort. The hardest part is getting the stack of clips back together and secured to the column, but like most things on our cars, pat inc and persistence gets it done.
    Alice the Time Capsule
    • JIM1inWisconsin
      • Dec 2014
      • 116
      directionals
      So the stack of clips either pulls away or detaches from the column and then you can remove the individual harness?
      • jeffnhiscars
        • Jun 2011
        • 6011
        That's correct. I believe the stack just slides out (up towards the steering wheel IIRC). I found it easier to maneuver them off as a group and then separate them. I think the only lock clips are on the individual pairs but double check.
