Fan blows warm when cold outside
  • Semblance
    • Jan 2011
    • 433
    so my fan tends to blow warm air even when it's chilly out and the temp is set to cold. Doesn't get that cold here, but even when it's in the 50s or 60s I've got noticeably warmer air than outside. AC doesn't work. Doesn't seem to happen when engine is cold so I'm guessing the heater is stuck on. Is it certain to be the heater valve, or is there something else I should check? Is there any other way to check if the valve is bad?
    '89 lachssilber vert - Frau Blücher
    '84 alpine 2dr - gone to the great beyond...
    '00 titanium 4dr e46 - bricked
  • george graves
    • 19996
    IIRC hot water is always flowing through the heater core. It's a air flap(s?) that direct the air through the core or not. So, I'd check both ends. The HVAC controls, and the flaps. Sounds like something isn't closing completely.
    Originally posted by Matt-B
    • Semblance
      • Jan 2011
      • 433
      Interesting. Too bad, I was hoping for fewer things to check out, not more :) So what does the heater valve do if it's always open?
      • AndrewBird
        The Mad Scientist
        • 11898
        The vent temp will always be slightly warmer than the air temp. No way around it. Your heater valve may be not closing all the way and causing it to be more warm than usual though. Worth looking at to see if anything is obviously wrong.
        • Semblance
          • Jan 2011
          • 433
          Yeah it's more than slightly. It's obnoxious. It was nice and brisk out and I was sweating with the fan on. I found this:
          That gives me enough to diagnose with I guess.
          • b-rad
            • Nov 2015
            • 232
            I have different issue but similar. At hwy speeds I get cold air, driving in neighborhood, I get great heat. Just had thermostat replaced. No overheating issues in engine
            1987 BMW 325is,(M3 S50 Swapped)-Current
            2010 FJ Cruiser, aka E30 Support Vehicle-(Daily)
            2008 Scion xB Lowered
            2001 BMW 325i
            1995 BMW 318ti
            1966 Ford Mustang Coupe
            1965 Ford Mustang Coupe
            My Thread
