Start engine without transmission?
  • Panici
    • Dec 2009
    • 2575
    I'm in the middle of an Auto -> 5-speed swap.
    I've just replaced my Rear Main Seal, and used "Permatex MotoSeal 1" with a new "Springless" style RMS.
    I'll be damned if I'm going to put the car back together just to have a leaky RMS because of the seal type, or the gasket material I used, or my improper assembly.
    So my question is this:
    Can I just bolt up the Auto flywheel, bolt up the starter (with a bracket/washers and shorter bolts) and start/run the engine with no transmission attached?
    (Assuming I'll need to do the wiring changes needed for the 5-speed swap in order to get the car to run without the Auto trans attached/plugged in)
  • whodwho
    • Jun 2008
    • 1547
    Pull the bellhousing off the auto trans
    My M20 Frankenbuild(s)
    4 Sale - Fully Built TurnKey Megasquirt Plug and Play EMS
    • Panici
      • Dec 2009
      • 2575
      Good idea! Starter should bolt right up to the bellhousing.
      Any foreseen issues just running the Auto flywheel?
      • whodwho
        • Jun 2008
        • 1547
        Shouldn't be an issue other than the engine will not be supported well. You will have to rewire for the starter at the shifter
        • bmwstudent
          • Sep 2011
          • 1364
          We do this all the time when we change rear main seals in tractor trailer engines, there shouldn't be any issue once you get the starter mounted.
