E30 24V brake switch wiring HELP!
  • jlukies93
    • Nov 2013
    • 8
    cant find a schematic or anything that remotely shows me how to wire or short the brake switch wires from my MS43 DME and I am hoping that once I find this information it solves my zero throttle response!!!
    do I hook the brake signal and brake test signal wires to ground or positive or the standard e30 switch???
  • TobyB
    • 5297
    If you ground the brake signal, the ECU will think the brakes are not on.
    Brake test, I have no idea.
    Might change the title of your post to MegaSquirt brake light wiring, as I was wondering why you had 24 volt brake lights...
    ...not to say that putting aircraft landing lights in there hadn't occured to me, but they're
    28v...
    hth
    t
