I was driving my 92 vert 325i and it just cut off and will not start up!!
  • chicagolande30
    • Aug 2014
    • 116
    I was driving my 325i vert automatic on Friday and the car just cut off power but it hesitated before it just turn off . It cranks but will not start . My friend who also has a E30 vert said it was mostly likely the fuel pump . I wanted know what you guys think since this is my 1st BMW so I am still learning alot about the car everyday . I know the same thing happen to me when I owned a 1993 VW Passat Vr6 and it was the fuel pump . Any advice would be great .
  • 8ball
    • Feb 2006
    • 157
    At the most basic principles it's either fuel or spark. Check your main wire to the coil to ensure it's not spark. You can try to test spark at the plug boot as well. It's easier to test spark than fuel. That should pretty much answer it for you.
    • Seawolf
      • Feb 2015
      • 270
      Undo the clamp, pull the MAF boot back slightly and fire some easy start into the intake. Try and start the car - if it starts your problem is either fuel delivery or fuel metering. If it doesn't start then it's an ignition or control (DME) problem.
      • 101
        • Jul 2011
        • 764
        I hate to add the obvious ... but remove the oil cap and have someone check that the cam is turning while trying to start the car.
        If that's OK, go for the spark check.
        If everything still passes, jumper the fuel pump relay and listen for the fuel pump.
        Let us know what you find!
        101
        The E30 collection:
        1987 325es M52 - Schwarz / Taurus Red Sport (son #2's)
        1987 325is - Delphin / Black Sport (son #3's)
        1987 325i Convertible - Triple Black
        1989 325iX Coupe - Diamondschwarz / Black Comfort
        1990 325iX Coupe - Sterling Silver / Grey Sport
        1981 Fiat 124 Spider 2000 - Green / Tan
        1998 Volvo V70 GLT - White / Tan
        1998 Volvo S70 T5 manual - White / Taupe
        2001 Ford Windstar - Silver / Grey (parts hauler)
        2006 Lexus GX470 - White / Tan (tow rig)
        • cWalk3r
          • Jun 2014
          • 178
          I would try this step first because its probably the simplist step, check your battery. Then take your rear seat off pull the connector off the fuel pump. Take a multi meter and set it on 20 volts. If you're getting 12v it's probably a bad fuel pump. If you're getting 1-11v could be the relay. If you're getting no volts it could be an incomplete circuit. Check for continuity when cranking the car. Again it could be the relay or a broken wire. Then I would check fuel pressure if the pump is good and spark after that.
          • chicagolande30
            • Aug 2014
            • 116
            I will go ahead and check everything one by one of what everyone suggested and I hope one of those things is the problem and I will fix it do I can get back to driving the vert again .👍
            • yosh
              • Aug 2009
              • 350
              In addition to the above, Main relay might be going. Fusible link might be busted, although I forget if verts don't have them. Bypass OBC if obc is messing up and not letting power get to ecu.
              • ///M42 sport
                • 3952
                check your relays
                • jeffnhiscars
                  • Jun 2011
                  • 6010
                  Timing belt
                  Relays
                  FP
                  Spark
                  In that order
                  Alice the Time Capsule
                  • mitchlikesbikes
                    • Dec 2013
                    • 858
                    check your fuel pump relay and fuse.
                    IG: @mitchlikesbikes
                    • e30onBBSs
                      • Dec 2014
                      • 1347
                      Easy way to check for fuel is to undo the hose clamp on the fuel line connected to the fuel pressure regulator then jump the fuel pump. Have a water bottle or something over the nipple of the fuel pressure regulator and when you jump the fuel pump gas should shoot right into the bottle if your pump is working.
                      Also make sure you have gas. I chased my own tail solving a similar problem even though I wasn't driving and it was just because the tank was empty and the gauge is broken. Unless you are 1000000% sure you have fuel pull the pump, it's super easy and shine a light into the tank.
                      Like someone else said, always check your battery first as well.
                      BMW tech
                      Umass Amherst
                      05 wrx sti
