Cat beads fluid through paint ?
  • ///M42 sport
    • 3952
    Just got done painting my cat w high temp por 15. Not sure why it's beading fluid. Was bone dry when I prepped
  • TobyB
    • 5296
    Looks like there was something under there....
    t
    • ///M42 sport
      • 3952
      I scuffed the whole surface w while brush and wiped down with rubbing alcohol. Weird that there is brown stuff beading through the paint
      • george graves
        • 20003
        Looks like rust is mixing with the paint and coming out.
        Not sure what you used, but I've never had good luck with high temp paint on anything other then a BBQ. I've painted exhaust manifold and the paint always burns off. Your cat is going to be even hotter then your manifolds - so yea. I know por makes good stuff, but I'm not sure even that is going to be up to the task.
        Someone tell me I'm wrong.
        Originally posted by Matt-B
        • E30SPDFRK
          • 5716
          Did you mix the paint well before using it?
          Byron
          Leichtbau
          • ///M42 sport
            • 3952
            the high temp paint is rated up to 1200 F. so i guess we will see. Kinda dissapointing to have this bead after spending all this time painting/prepping.
            • TimeMachinE30
              • Jun 2014
              • 3749
              Metals can hold water. The piece needs to cook the water out before painting.
              It seems there was water present.. and only after the painting has the piece been heated and water is now trying to escape.
              ACS S3 Build / Dinan 5 E34
              • rommaster2
                • Mar 2014
                • 89
                With high temp paint like that in order for it to properly adhere it has to go through heat cycles to treat the paint onto the metal.
                On a side note a properly operating cat can operate at high enough paint to be at the limit of the high temp paint even properly cured.
