shuddering/banging/thumping under hard acceleration/torque - I'm stumped - HELP
  • Sh3rpak!ng
    • Jan 2014
    • 2667
    1989 325i s52 swapped with g260 trans, JBR 11lb flywheel, 3.23 LSD
    While driving home about 3 miles from home I accelerated from a turn and felt a shuddering/bumping as if I was driving over a bunch of tiny bumps. It was weird, so after next light, I accelerated hard again and felt the same thing happen. It can be felt through the seat and through the shifter. It almost sounded like the driveshaft was banging around. I drove home carefully and paid close attention. I could ever so slightly feel this as I drove in other gears, but not even close to how bad it is under hard acceleration and torque. I could only recreate the problem in 1st and 2nd.
    I was planning to do a bunch of work on it anyway, so I started taking stuff apart to see if I could notice anything obvious.
    -took cover off diff and drained fluid; it looked normal
    -removed 2nd half of driveshaft to inspect U joint; it looked normal
    -the CSB is new, but looked normal
    -half shafts looked normal (I also just replaced one and rebuilt the other)
    -wheel bearings seemed fine as far as I could tell? (no play when shaking the tire on an angle)
    -guibo looks fine (probably could be replaced, but didn't seem to be an issue)
    Also, all suspension bushings are new, coilovers are new, tires are new, brakes are new, and the engine was just entirely rebuilt (by me :) )
    So needless to say, I am totally stumped on this one.
    Shadetree30
  • vpilarrt
    • Jun 2006
    • 2096
    Make sure the driveshaft halves are aligned. It's hard to see damage on the guibo unless you remove it.
    • Sh3rpak!ng
      • Jan 2014
      • 2667
      They are aligned. The car was driving perfectly fine for a few months, this issue just popped up suddenly.
      I am doubting it's the guibo. THe symptoms don't match a failing/failed guibo (I've killed one in my e36). Starting to suspect the DS U joints after some googling. Seems to be a "common" high mileage failure.
      Shadetree30
      • Andy.B
        • Sep 2011
        • 1650
        This is EXACTLY what happened in my gf's e30. The giubo failed after several months of poor driveshaft alignment.
        It came on suddenly, and was pronounced when accelerating in 1st and 2nd.
        • TravisAsch
          • Jul 2015
          • 34
          I just did a guibo & csb & am still dealing with a driveline vibration. I am leaning towards the diff mount bushing
          • Sh3rpak!ng
            • Jan 2014
            • 2667
            Well what I've read is that CSB failure is usually the result of u joint failure or other DS alignment issues. I just replaced the CSB because it was totally torn up.
            Shadetree30
            • Sh3rpak!ng
              • Jan 2014
              • 2667
              Not sure that's it. I replaced mine thinking the same thing and it changed nothing. And the original bushing was shot.
              Again, should've googled first, but I am suspecting the U-joints. From what I've found from googling, most of these driveline vibration problems are rooted in bad U-joints which cause the CSB/guibo to wear out.
              Shadetree30
              • TobyB
                • 5280
                If it's NOT the u- joints, it might be the LSD itself- when the clutches weld up, or have
                the wrong fluid, they can skip or bind/release... hope it's not that....
                t
                • Sh3rpak!ng
                  • Jan 2014
                  • 2667
                  t
                  I don't think so, but I could be wrong. The fluid was clean when I drained it (it was only 6 weeks old). Using the correct fluid (redline 57904 75w-90). And I cobbled the diff together (e30 3.23 case with an e36 LSD unit) and the LSD unit was known good and working from a friend's car. Either way, it's out of the car, drained, and apart so I guess now would be the time to replace the clutches and dog eared plates.... $$$
                  Shadetree30
                  • ahlem
                    • 369
                    When you put torque on the system as you accelerate, things move around a bit. Is anything in close proximity to the guibo nuts or bolts? The flutter could be due to flex on engine or trans mounts shifting the drive train enough to hit on something. Check for light wear marks where the bolts hit on the back of the transmission or anything else in that neighborhood. What motor and trans mounts did you use?
                    • Sh3rpak!ng
                      • Jan 2014
                      • 2667
                      Good suggestion. I'll check tightness on all the mounts. Though I have my doubts, it can't hurt. Just replaced the rear output seal on the trans and tightened all that stuff up again.
                      Mounts are all brand new (~2 months), they went in with the new motor. Revshift green poly swap mounts and condor uhmw trans mounts.
                      Shadetree30
                      • CorvallisBMW
                        Long Schlong Longhammer
                        • 13039
                        Check your engine and trans mounts. Sounds like you could have some failed ones.
                        • Sh3rpak!ng
                          • Jan 2014
                          • 2667
                          Doesn't make sense (because they're brand new), but I will.
                          Shadetree30
                          • CorvallisBMW
                            • 13039
                            Oops, didn't see that part. disregard.
                            • Cephas
                              • Apr 2012
                              • 878
                              I had very similar issues and it was the u joints. Driveshafts aren't that expensive anymore, thankfully.
