Electric antenna woes
  • HarryPotter
    • Jan 2010
    • 3642
    The problem is the antenna motor does work and it will pull down the antenna when I shut the car off, but when I turn it back on with the radio on it won't go back up. This is electrical most likely cause if I unplug the power connector and fiddle with it the mast will go back up when the cars on. I had previously just put it up and removed the plug so it just stayed up, but I am trying to get everything working. Could it be the little circuit board or something or bad contacts on the plug? I just don't understand how it will power down and retract but not go back up without fiddling with the plug.
    I am going to go fiddle with it some more but any suggestions would be very helpful.
    Been really doing a lot to the car lately after kind of ignoring it for a long time due to personal issues. Just trying to get everything sorted.
    John F. Kennedy
  • HarryPotter
    • Jan 2010
    • 3642
    Definitely just a loose connection if i plug it in just right it works, I hit it with electrical cleaner and it seems to be working alright now, I am sure after some spirited driving it will stop working again lol.
    John F. Kennedy
    • spdracrm3
      • Sep 2009
      • 959
      cracked solder
      yup just had this happen on my IX , remove the board and look really closely at the solder joint on underside (magnifying glass helps),i found two of the larger ones cracked completely in a circle around the pin ,reflowed them and all is well now
      this is usually all that is wrong with the power antenna's that folks give up on
      Angus
      88 E30M3 X2
      89 325IX
      92 R100GS/PD
      • HarryPotter
        • Jan 2010
        • 3642
        Thanks I will check that out. I just replaced the grommet and that was a bitch now I don't feel like pulling the antenna out again lol.
        John F. Kennedy
        • HarryPotter
          • Jan 2010
          • 3642
          Boards fine, it's so weird I cleaned up all the connections and it works but if the plug moves a certain way it doesn't. I really have no idea what it could be at this point. Maybe the inside of the plug connectors are corroded. They seemed fine though. It is working right now but I am sure it will stop here soon. Motors fine, everythings fine, plug is fucked but looks fine, sense this makes none.
          John F. Kennedy
          • spdracrm3
            • Sep 2009
            • 959
            yea could be the connector or a broken wire (worth cleaning them and applying some dielectric grease) ,and remember as you move the connector you could be flexing the board which could cause a bad connection on it to appear
            i need to do the grommet on mine now too as it cracked after reinstalling the antenna ....
            Angus
            88 E30M3 X2
            89 325IX
            92 R100GS/PD
            • jeffnhiscars
              • Jun 2011
              • 6011
              There ar a couple of different control board designs and one has separate contacts to co troll up and down. If you have those check to see they are clean
              Alice the Time Capsule
