Which oil to use
  • smokeyyank
    • Jun 2015
    • 31
    Which oil to use
    First, yes I have searched and I know this topic has been beaten to death, but I still can't find a good answer as I think it all depends. So my question is which oil should I use for MY car? I just purchased it and need to change the oil. I don't know what the PO used, but I can see a purrolator oil filter so my guess is whatever Midas put in it. I live in Colorado, currently has about 150k on the engine, car is only going to be driven in nice weather (my guess on temps would be between 40-100), this isn't my daily so it may sit for a while at a time and I have a lead foot. I'm leaning towards Castrol 10w40 non syn. Thoughts?
    Thanks
  • wannaBMthree
    • Apr 2007
    • 601
    20w-50, vr1
    • efficient
      • Feb 2012
      • 3312
      Vr1 kills cats. Says on the bottle
      • smokeyyank
        • Jun 2015
        • 31
        So I know the VR1 says it is bad for cats, but since this isn't a DD and I'll probably change the oil twice a year would that really matter?
        • gwb72tii
          • Nov 2005
          • 3864
          how about what the owner's manual says?
          “There is nothing government can give you that it hasn’t taken from you in the first place”
          Sir Winston Churchill
          • smokeyyank
            • Jun 2015
            • 31
            gwb72tii, I agree, and I think it's just regular 20w50 and then changes for winter, but what I've been reading is that since oil has changed so much over the years along with its characteristics what was recommended back then may not be the best now. Hence my conflicting info about which oil I should use for my specific application.
            • estoguy
              • May 2013
              • 1087
              I've been using Castrol Edge 5w50 for the past couple of years. Seems to be doing the trick.
              Estoguy
              • ELVA164
                • 4861
                As mentioned, the manual is outdated and inaccurate. In Denver you could use Mobil 1 0W-40 year round. I've done so for a year and a half here and it's worked great. Mobil 1 15W-50 would work well too. Both have sufficient ZDDP and a good track record. For the record, I contacted Mobil and BMW separately about this and they each recommended the 0W-40.
                • dnguyen1963
                  • Nov 2011
                  • 2648
                  I have been running Farm and Fleet diesel oil 15W40 ($8 a gal) for years...
                    You want an oil with a high ZDDP content because of the flat/sliding rocker arms. There are a number of pure race oils with satisfactory ZDDP levels, but they aren't intended to be in the engine as long as a more conventional oil with detergents.
                    A couple of oils that are suitable and have sufficient ZDDP to protect the cam and rockers include Amsoil Z-Rod 5w50 and Shell Rotella T. The best oil filter is a Mobil one and second best is OE or Mann.
                    • smokeyyank
                      • Jun 2015
                      • 31
                      Alright thanks for all the info. I had been reading about an oil that has enough ZDDP and while I'm not opposed to a race oil just want to make sure I'm putting in what it needs.
                      • jeffnhiscars
                        • Jun 2011
                        • 6010
                        You should be opposed to a race oil for off track use. They are intended for far more frequent changes and sever use than "street oils"... Not to mention they typically cost quite a bit more than even M1.
                        I can't believe this ismstil being talked about
                        Alice the Time Capsule
                        • AndrewBird
                          The Mad Scientist
                          • 11897
                          Nothing wrong with running race oils in a street car, you just have to be aware that it needs to be changed more. The only reason to run them is the high levels of ZDDP (zinc), which is what clogs up cats. This is why modern oil has low ZDDP levels.
                          You can also buy ZDDP additive and then use whatever oil you want.
                          I prefer 20W-50 VR1, except in the winter when it is consistently near or below freezing. Then I run 10w-30. I usually buy it on sale at Autozone for $3 a quart.
                          • smokeyyank
                            • Jun 2015
                            • 31
                            Went with Mobil 1 0W-40. Thanks for the info!
